Weird fork noise after oil change - Victory Forums - Victory Motorcycle Forum
post #1 of 8 (permalink) Old 05-15-2018, 05:38 PM Thread Starter
jpilot17's Avatar
Hey fellas,
I just changed my fork oil and this is what my forks sound like now. Definitely concerned.
https://youtu.be/sHQUBE2WCno
I put in the same amount of oil in as I took out. Everything is tight. Manual says not enough oil... help!!
2012 Crossroads Classic
Cobra Tri-Ovals
Lloyds Timing Wheel +4*
jpilot17 is offline
post #2 of 8 (permalink) Old 05-15-2018, 07:17 PM
If you replaced what came out, you should be OK, unless you had leaking forks prior to the job. Are you certain you got all the parts in correctly?
Re correct amount, I have been researching for a fluid height measurement for Cross bikes and so far, zip. What I'd like to know is a measurement with the forks in place, bike vertical and the caps off. Anyone know that or where to find it?
post #3 of 8 (permalink) Old 05-15-2018, 10:51 PM Thread Starter
jpilot17's Avatar
Yeah. The only part I undid on the fork itself was the cap to drain it and refill it as per a YouTube video I watched. Don't know how I could have screwed that up.
Cobra Tri-Ovals
jpilot17 is offline
post #4 of 8 (permalink) Old 05-15-2018, 11:20 PM
Which video did you watch? Apparently you weren't doing new seals.
post #5 of 8 (permalink) Old 05-15-2018, 11:52 PM
BP6666VR's Avatar
Hmmmm so you only
1. opened the top cap of the forks and sucked the old fluid out and put the new fluid in,
2. measured from the top to oil, coz you do not want 1 or 2 centimeter difference in the 2 tubes ...
3. Closed the caps and noise started ....
Maybe air ?
Andre using TaPaTaLk
Cross Country Tour 2014 [B]
BP6666VR is offline
post #6 of 8 (permalink) Old 05-16-2018, 01:41 AM Thread Starter
jpilot17's Avatar
Originally Posted by BP6666VR View Post
Hmmmm so you only
Maybe air ?
This is the video I followed:
https://youtu.be/yRFDleX_9g4
But I have a bigger problem now. I tried to take the caps off to pump the fork to get rid of any Air, and my socket skipped off rounding the edges. I am fucked. I tried filing the edges square, using a 21mm instead of 22, vice grips. I guess I'll be bringing it into the shop tomorrow. 😑 live and learn I guess.
Cobra Tri-Ovals
jpilot17 is offline
post #7 of 8 (permalink) Old 05-16-2018, 06:00 AM
BP6666VR's Avatar
Ouchhhh sorry to hear that ... But you had a problem already, maybe this was your "luck" so to speak that your forks will be perfect again,
May i suggest that you will be present at the front fork repair so you will know what was wrong with them ...
For your caps, see the link below, click on the year and bike and front fork, then buy them , just to be safe
https://www.victoryparts.net/oempart...torcycle/parts
BP6666VR is offline
post #8 of 8 (permalink) Old 05-16-2018, 08:03 AM
gamewarden's Avatar
Sounds like the forks are grinding somewhere. Definitely a problem. The top caps are only to be tightened snugly so getting them off should not be a problem. I would take both shocks off and take them to somebody who really knows their stuff.
2011 custom Tequila Gold with Candy Orange accents, hard lowers and trunk, Ipod in lowers, HID and saddle bag bars, stage 1, heel shifter, front and back chrome fender guards,Garmin GPS, fairing wind deflectors, heated Gerbing hook up, Dain skull brake pedal, rear brake master and reservoir cover, custom cheese wedge cover, clutch cover, Witchdoctor cam covers, Wolo Bad Boy horn, heated grips and seat, Gorilla alarm, Vision rear engine brackett covers, Kruzer Caddy, WD exhaust tips.
gamewarden is offline
