Better speaker between the 2. Kicker or polk - Victory Forums - Victory Motorcycle Forum
post #1 of 6 (permalink) Old 05-28-2018, 07:11 PM Thread Starter
Default Better speaker between the 2. Kicker or polk
I pulled my grills out and realized I have the kicker premium speakers from factory in the bike already. Which will be better for use with RF 300 watt amp. The kicker premium or the Polk 522 I purchased? I got the polks bc they were recommended with amp and on the forums here.
Suede
jtirwin27 is offline
post #2 of 6 (permalink) Old 05-29-2018, 01:36 AM
Generally anything will sound better with an amp. Do the kickers run off an amp? If they do then you are probably fine running them. If there is no amp then I would just shelve the 522 and add amp to run the kickers until they die.
post #3 of 6 (permalink) Old 05-29-2018, 02:12 AM Thread Starter
No amp. Just factory head unit. I picked up polks bc they are marine grade and I ride year round. Just didn't know if one was better than the other.
Suede
post #4 of 6 (permalink) Old 05-29-2018, 08:32 AM
Better is somewhat subjective. If they are a factory option they probably sound good. I just installed 522 in mine to replace the generic junk speakers (not kicker) because I'll probably add an amp later and it would blow the stocks. Sound is a little better even without an amp.
You would need to find the model number to compare the kickers to the 522 specs.
If they sound fine no harm keeping the 522 for backup.
post #5 of 6 (permalink) Old 05-29-2018, 05:23 PM Thread Starter
I ended up comparing the two on radio only. The Polk 522 has a much larger magnent than the kicker. Added poly fill and sound mat I'm speaker cups. Polks sound much clearer on radio alone. I expect the amp to really make them shine.
Suede
post #6 of 6 (permalink) Old 05-29-2018, 08:22 PM
My Polk up front sound great but lack bass of course. I kept the old speakers not sure why the rear trunk sounds so bad. Muffled. I'll have to dig into it later but it gives me fake bass that the front is lacking.
If you do the amp post pics I'm curious how that mount works.
