Vic likes heat...or is it my imagination? - Victory Forums - Victory Motorcycle Forum
 22Likes
post #1 of 24 (permalink) Old 06-11-2018, 06:38 AM Thread Starter
Default Vic likes heat...or is it my imagination?
Seems to me the 106 prefers running in hot (80+ degrees) as opposed to below 50. Is this possible? Is it my imagination?
S&S Cams, Lloydz filter & ATS +5, PCV, UD pulley, Alto Red Eagle clutch pack
Madstad Windshield, 5000K HID, TriOvals, Memphis Shields wings
JVC KD-X33MBS, PBR300X4, Polk DB6502, DaytonAudio ND140-4 rear
HyperLites, LED driving lights, hydraulic clutch, Ultimate seat
post #2 of 24 (permalink) Old 06-11-2018, 07:37 AM
vindex1963's Avatar
I can't tell much difference in the motor running between 50 and 118 but always felt air cooled motors prefer cooler weather.
RICZ and BP6666VR like this.
1/4 turn throttle ring
Tank riser
VM-1 DR cams
Timing wheel +4
Lloydz high-flow air cleaner
Bassani baffled OEM mufflers
PC-V 118hp 116tq
vindex1963 is offline
post #3 of 24 (permalink) Old 06-11-2018, 07:49 AM
BP6666VR's Avatar
At night i think my vics run better then in the blistering daytime heat....
Andre using TaPaTaLk
Cross Country Tour 2014 [B]
BP6666VR is offline
post #4 of 24 (permalink) Old 06-11-2018, 07:56 AM
kezzy39's Avatar
A lot of extra engine noise when running hot.
2014 Cross Country. Stage 1 Exhaust Upgrade. LED Headlight. Keyless Ignition. Victory Chrome Bling.Winnipeg Manitoba Canada.
kezzy39 is offline
post #5 of 24 (permalink) Old 06-11-2018, 09:36 AM
VicVisionBulldog's Avatar
It seems to me mine have more pop in the cooler temps.
VVB
13 Vision Tour - PCV, Top Filter, Stage 1 Pipes, TW @ +4, Metz 888s
VicVisionBulldog is offline
post #6 of 24 (permalink) Old 06-11-2018, 11:38 AM
Cooler air is more condensed and brings more O2 into the cylinders. So engines should run stronger in cooler temps.
post #7 of 24 (permalink) Old 06-11-2018, 12:57 PM
was out yesterday 69 degrees and I swear it had more power. I think humidity and dew point makes a big difference. Cause the air is heavier
post #8 of 24 (permalink) Old 06-11-2018, 02:29 PM
Ferta_McDaniels's Avatar
Well, the masses have spoken. It is your imagination.
broggyr and Motorbikerx like this.
PFloyd (Ferta)
2014 Vision Nuclear Sunset
XM Radio Module
Sequential Turn Signals F/R
1/4 Turn Throttle Ring
HID Headlights & Cyclops
Vic Shop Tweaks: 124 HP / 121 Torque
04 Purple Thunder Kingpin (Sold)
Ferta_McDaniels is offline
post #9 of 24 (permalink) Old 06-11-2018, 04:40 PM
Honda East Toledo's Avatar
I think the sweet spot for my last bike was between 55-65 degrees, no/low humidity and at sea level, best MPG and would carry the wheel anytime you looked at the throttle.
visionjohnny, broggyr and yago20 like this.
(419) 891-1230 ext 235
(877)-437-1631
http://www.hondaeasttoledo.com
http://www.hondaeastsuperstore.com
Like us on Facebook
Follow us on Twitter!
Honda East Toledo
Indian Of Toledo
1230 Conant St.
Maumee, Ohio 43537
Honda East Toledo is offline
post #10 of 24 (permalink) Old 06-11-2018, 06:06 PM Thread Starter
I do have a vivid one.
