Do you use fuel with Ethanol? - Victory Forums - Victory Motorcycle Forum
 58Likes
post #1 of 81 (permalink) Old 06-12-2018, 05:30 PM Thread Starter
Dcc
Default Do you use fuel with Ethanol?
The guy at the motorcycle shop said don’t use gas with ethanol. I read in the CrossRoads manual that it was OK. Just wondered what others do??
Dcc is offline
post #2 of 81 (permalink) Old 06-12-2018, 06:22 PM
doobliss's Avatar
Originally Posted by Dcc View Post
The guy at the motorcycle shop said donít use gas with ethanol. I read in the CrossRoads manual that it was OK. Just wondered what others do??
It's hard to find ethanol free gas anymore, and when you do find it, it's much more expensive than standard gas. Our bikes are designed to run 10% ethanol or less.
yago20 likes this.
'15 Gloss Titanium XC.
WOLO Low Tone Disc Horn
Tri-Oval Slip Ons
Black LED Headlight
Kingpin Metal Fork Guards
Ricz Lay Down Plate
Lloydz Timing Wheel & Throttle Ring
Shinhopples Grip Covers
12" Long Ride Shield
Bad Ace Billet Fork Mounted Air Deflector
Ness Signals; Amber front, Red rear
http://www.pure-gas.org/
"I leave the BUG CARNAGE on my screen , it adds character!"-LILMAGS500
doobliss is offline
post #3 of 81 (permalink) Old 06-12-2018, 06:29 PM
depot picker's Avatar
I use it. never noticed any difference.
half_crazy and Endeavor like this.
depot picker is offline
post #4 of 81 (permalink) Old 06-12-2018, 06:33 PM
541RF's Avatar
I use it, but I use Premium gas with no problems.
541RF
2004 Arlen Ness Signature Series Vegas
Black-Cherry Fade
Stage one dealer kit installed
Bags, tour seat with backrest and rack
Southern, OR.
541RF is offline
post #5 of 81 (permalink) Old 06-12-2018, 06:33 PM
TNXR's Avatar
There are a bunch of non-ethanol stations around me because of the multitude of lakes. I keep a very detailed spread sheet for every gas fill up and after 6 years of data it shows I get better gas mileage out of the ethanol blended gas (10%) than I do the non-ethanol. I also can tell no difference in power or engine smoothness between the two. I'm a cheap a** and usually run 89 octane from a name brand station and throw a little 93 in there when it gets really hot in July & August.
2011 Cross Roads Sunset Red
TNXR is offline
post #6 of 81 (permalink) Old 08-29-2018, 07:45 PM
BP6666VR's Avatar
I saw this and enjoyed watching it, but apparently it does not work this way, the comment section has some good points , for some reason i cannot copy the best one ...
https://youtu.be/kSnE4MYwRzs
https://youtu.be/QH2zgomFdEM
Andre using TaPaTaLk
Cross Country Tour 2014 [B]
BP6666VR is offline
post #7 of 81 (permalink) Old 08-29-2018, 08:53 PM
ScabbyDoo's Avatar
In most areas today it is difficult to find ethanol free gas. For this reason, if for no other, I always use at least 92 octane. One reason is that ethanol produces a lower level of combustion, therefore lower power per detonation. I also regularly add an enzyme fuel additive designed to guard against the other issue with ethanol, the fact that it attracts water. This can prove harmful to your engine in at least two ways; first is the direct harm moisture can do to your engine and second is that it shortens the 'shelf life' of the gasoline.
2014 CrossCountry
B&E Performance "Atom Bombs"
Lloyd'z High Flow Filter
PVcx Dyotuned by JD's Cycle Works
95.5 hp / 112 tq
Klock Werks Windshield
ScabbyDoo is online now
post #8 of 81 (permalink) Old 08-29-2018, 10:26 PM
E10 will not give our bikes any problems, except during winter hibernation. On the last ride of the season, I fill with pure gas top with a fuel stabilizer. Gasoline has about a 30 day shelf life and then the gooey stuff begins to ooze out. If you can't fill with pure gas, then top with Startron enzyme fuel treatment - stops the evils of ethanol.
https://www.westmarine.com/buy/star-...SABEgKZifD_BwE
wspollack and MonsterMash like this.
post #9 of 81 (permalink) Old 08-30-2018, 08:27 AM
Judge Redd's Avatar
Ethanol free only unless I am forced to do otherwise.
LOTS of ethanol free out there- especially away from larger towns. Better mileage / range for me. I have a station about 4 miles away. He carries 87, and the bike seems fine with that, but I will use higher octane when I find it.
2014 Judge(Havasu Red) PC-V - ATS(+4) - RPW Boom Sticks - HOHVM1-DR cams - Torque Tubes (dyno sheet) 1/4 turn throttle - OPT7 LED headlight kit - OEM bags, backrest, and W/S
Judge Redd is offline
post #10 of 81 (permalink) Old 08-30-2018, 08:40 AM
toejam's Avatar
https://www.pure-gas.org/index.jsp
2013 Anti-Freeze Green XC
Vance & Hines Slip On's
BadBoy Horn, PCV
Gustafsson +4 Windscreen
Picasso Nano PN2.350D Amp
HMD520 Gorilla Bagger Bars
2010 XC 116 Big Bore - Gone
2006 Hammer - Gone
toejam is offline
