CR/CC/CCT Fork Rebuild Kits - Victory Forums - Victory Motorcycle Forum
 25Likes
post #1 of 18 (permalink) Old 06-20-2018, 09:51 PM Thread Starter
Default CR/CC/CCT Fork Rebuild Kits
I'm planning on changing the fork fluid and rebuilding my forks soon. I was looking over on Victoryparts.net for the items I'll need.
2204214, Kit-Seals, Bushings, $52.20/leg, $104.40
7556548, Spring Guide-Lower, $3.89/leg, $7.78
7556549, Spring Guide-Upper, $3.60/leg, $7.20
I'll be at 60K miles soon and the fork oil hasn't been changed since 15K miles. I figure while the fork legs are off I may as well change the common wear items. Does this look like all the normal wear parts to you who have done this job?
All the best,
Mark
www.bikersforchrist.org
"That's a beautiful Victory!"
"Thank you."
"Who makes it?"
"No one."
Chattanooga Mark is offline
post #2 of 18 (permalink) Old 06-20-2018, 10:23 PM
Have you looked into Witchdoctors for those parts?
post #3 of 18 (permalink) Old 06-20-2018, 10:37 PM
I'd check Race Tech also. See if they know what the fork is and if they do they should have parts.
Vic doesn't make their forks, They are purchased to Vic's spec from an OEM based on one of the OEM's series of forks.
The parts you buy from Vic will also be re branded parts from that OEM.
If you get them from Racetech they will come in the OEM's package, same part.
Racetech is a distributor for most foreign forks here in the US and there markup isn't as high as say HD's is on HD fork parts. (showa) You maybe able to save some money that way.
I would imagine that Traxion might also be a distributor for foreign fork parts also. Might check there as well.
You might have to take a few measurements or send a couple of pictures to ID it. But it might be much cheaper.
presently owned bikes
1993 HD fxrp
1982 HD Sturgis
2009 Honda rebel
co owner
Joe_ is offline
post #4 of 18 (permalink) Old 06-21-2018, 07:02 AM
depot picker's Avatar
I would not do the bushings unless they are actually causing a problem.
depot picker is online now
post #5 of 18 (permalink) Old 06-21-2018, 08:57 AM
Motorbikerx's Avatar
Yeah was about to say same thing, bushings will be ok, and aftermarket seals a hell of a lot cheaper too, I used the All Balls ones.
Full Synthetic fork oil after using normal to flush them
Chattanooga Mark likes this.
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is offline
post #6 of 18 (permalink) Old 06-21-2018, 11:28 AM
BREAKING NEWS......I'm picking up a pair of rare CHROME forks for my XR. Local indie Vic shop got them with a buyout of a dealer. Getting them for a fraction of list. Photos to follow when I get them later today. I can't think of any Cross bike with an 18" front wheel that had chrome forks, can you?
post #7 of 18 (permalink) Old 06-21-2018, 01:32 PM
I'll guess if you mike the used parts and compared to the new ones you'll find very little wear. Keep in mind polaris came up with these low mileage numbers so dealers could make money off us
post #8 of 18 (permalink) Old 06-22-2018, 09:07 AM Thread Starter
I have, they were higher priced than victoryparts.net
Racetech only lists Gunner, V92C and Vegas on their website. I'll call their main Corona, CA number (951-279-6655) when they open for business. I can't imagine them not having the seals available. I agree on all the comments above. Polaris doesn't 'make' this type of part, they only spec out from a list of industry standard items. Just like brakes, calipers, bearings etc.
All the best,
Mark
"Thank you."
"Who makes it?"
"No one."
post #9 of 18 (permalink) Old 06-22-2018, 07:40 PM
If you get someone who isn't of any help on their sales line call back and select tech help through the menu and then Louie. He is very knowledgeable and experienced as is the other fellow who often picks up his line.
He can also do sales or could, I am guessing that one of them will be able to figure out what you have.
I'd like to know who made the fork myself as down the road that will be important to me finding wear parts when my turn comes.
1993 HD fxrp
1982 HD Sturgis
2009 Honda rebel
co owner
Joe_ is offline
post #10 of 18 (permalink) Old 06-22-2018, 08:48 PM Thread Starter
I did call Race Tech and spoke with Lou. He didn't know anything about the Victory Cross bike forks and wasn't at all interested in finding out. I suggested it should be a somewhat 'standard' item so he asked me what the fork diameter is. I didn't have it off the top of my head and will measure them with calipers. I'll call back on Monday and since I'll have the fork tube size, perhaps I'll be able to get a RaceTech part number. I'll report back.
Joe_ likes this.
All the best,
Mark
"Thank you."
"Who makes it?"
"No one."
