Unused connectors next to ABS under rear fender? - Victory Forums - Victory Motorcycle Forum
 1Likes
  • 1 Post By IndyVictory
post #1 of 7 (permalink) Old 06-23-2018, 03:10 PM Thread Starter
Default Unused connectors next to ABS under rear fender?
Okay I'm curious what are these seemingly random connectors next to the ABS unit on a 2012 CCT?
Obviously never been used lot of corrosion.
I'm finding lot of unused connectors all over this bike this is just the latest.
The location is so inaccessible I don't know what would use this.
Red 2012 Cross Country Tour
Polk 522, Nautilus air horn, 17" rubber antenna, knob saddlebag release, black tri-ovals, sabertooth saddlebag lights, Madstad windshield, many parts chrome to black.
post #2 of 7 (permalink) Old 06-23-2018, 08:58 PM
I have a 2012 CCT and when installed the saddlebag audio system I ended up using a couple of the unused connectors. Frankly I was impressed at how the main wiring harness was already made for some accessories Polaris only made available long after my 2012 was put together. The rear speaker amplifier mounts under the rear fender near the ABS unit.
All the best,
Mark
www.bikersforchrist.org
"That's a beautiful Victory!"
"Thank you."
"Who makes it?"
"No one."
Chattanooga Mark is offline
post #3 of 7 (permalink) Old 06-23-2018, 10:26 PM Thread Starter
Hmm so is that what those connectors are for?
Just seems an odd place to have exposed connectors unless the prior other removed whatever was connected back there.
post #4 of 7 (permalink) Old 06-23-2018, 10:43 PM Thread Starter
Ah found post on the other forum that's 12V for plug in right bag.
Now I have another project to do.
post #5 of 7 (permalink) Old 06-24-2018, 12:33 AM
Tha's a find!
presently owned bikes
1993 HD fxrp
1982 HD Sturgis
2009 Honda rebel
co owner
Joe_ is offline
post #6 of 7 (permalink) Old 06-24-2018, 10:42 PM
You also have a 12VDC switched two wire female plug under the tank along the front left side. It's in the main harness for the driving lights kit for the CR. I used those wires and a switch on my CCT dashboard to power the coil of a relay to power my CCT driving lights.
The switched 12VDC in the saddlebag was for the CC, not the CCT. But if it's another switched power connection it would work just fine to add a power outlet to the saddlebag.
The forward thinking went pretty deep with the engineers who designed our motorcycles.
All the best,
Mark
"Thank you."
"Who makes it?"
"No one."
post #7 of 7 (permalink) Old 06-25-2018, 03:06 AM Thread Starter
I don't know so much that it was forward thinking but cost savings. You build a frame with a harness and the final product can be whatever demand requires.
Switched power would be good for a relay. The kuryakyn light kit uses the heated grips connection in fairing to trigger relay so only power when engine running.
Chattanooga Mark likes this.
