abs light - Victory Forums - Victory Motorcycle Forum
 4Likes
post #1 of 12 (permalink) Old 07-27-2018, 01:43 PM Thread Starter
psychodiablo's Avatar
Send a message via AIM to psychodiablo
Unhappy abs light
the abs light came on while on a ride today. where should i start to find out what caused it. the brakes work fine and no other issues.
Leesville Louisiana. 2012 cross country, speedo upgrade,forged engine guard,touring sheild, tri oval pipes, Lloyds gen 3 fuel controler, Lloyds highflow airfilter. Lloyds timeing wheel, msd coils,Lloyds 8.2 mm red wires,tank lift/spacers,tank wings,side cover scoops,audio input cord,drivers back rest, 2in pull back bars,polk 5.25 speakers,XC Mag baffles,rockford fosgate pbr400x4 amp,lower wind deflectors,sylvainia ZXE Gold h-11 headlights. rivco hiden hitch. IDMW,FYIYDLMOMB.
psychodiablo is offline
post #2 of 12 (permalink) Old 07-27-2018, 06:08 PM
SuperDog's Avatar
Possibly one of the wheel speed sensors or associated wiring. Its where I would start. others will chime in as I believe a few others have had theirs come on too.
"Be Water, My Friend" Bruce Lee 1971
2013 CCT Grasshopper Drivers Backrest, PVC Self Made 1/4 turn Throttle Ring, Thrush Self Modded Mufflers, Kuryakyn 4526 Tour-Tech Adjustable Cruise Mount/Tour-Tech Pegs
SuperDog is offline
post #3 of 12 (permalink) Old 07-27-2018, 06:19 PM
Check the sensors they have a required clearance spec and if off the light will trip. Not had symptoms but already read about it. Spec in manual.
post #4 of 12 (permalink) Old 07-27-2018, 07:06 PM
djh3's Avatar
Simple free stuff to look at. Tone ring on wheels, make sure no broken or missing teeth. Also look that no junk is filling in the slots in-between teeth. Then you might remove the sensors and see if they have contacted and are clean. Then as mentioned the air gap spec.
depot picker likes this.
2013 XCT added Jan 2015
djh3 is offline
post #5 of 12 (permalink) Old 07-27-2018, 07:16 PM Thread Starter
i will dig in to it a lil more tomorrow.
post #6 of 12 (permalink) Old 07-27-2018, 07:17 PM Thread Starter
thanks for the advise.
post #7 of 12 (permalink) Old 07-28-2018, 07:31 AM Thread Starter
i found the rear sensor wire some how had got to close to the dam brake rotor and cut the wires. i reconnected them but the light didnt go out.
post #8 of 12 (permalink) Old 07-28-2018, 07:32 AM Thread Starter
sensor wires go to close to rotor and was cut.
post #9 of 12 (permalink) Old 07-28-2018, 06:46 PM
depot picker's Avatar
They're only about $100.
depot picker is online now
post #10 of 12 (permalink) Old 07-28-2018, 07:20 PM Thread Starter
i was able to splice in a couple pieces of wire and everything works again.
