Rear Sprocket Bolt Torque - Victory Forums - Victory Motorcycle Forum
 9Likes
  • 1 Post By djh3
  • 1 Post By Tenax
  • 1 Post By Tenax
  • 2 Post By djh3
  • 2 Post By IndyVictory
  • 1 Post By depot picker
  • 1 Post By djh3
post #1 of 10 (permalink) Old 08-11-2018, 08:10 PM Thread Starter
snojunkie's Avatar
Default Rear Sprocket Bolt Torque
Hi everyone , I have a 2014 CCT and was wondering what the Torque values are for the 5 bolts on the rear sprocket, and the rear axle nut? Also should I use Locktite on these NEW bolts?
snojunkie is offline
post #2 of 10 (permalink) Old 08-11-2018, 09:08 PM
djh3's Avatar
If I read it right the sprocket bolts are 55 ft lb. The axle nut is 65 ft lb.
snojunkie likes this.
2013 XCT added Jan 2015
djh3 is offline
post #3 of 10 (permalink) Old 08-12-2018, 07:30 AM Thread Starter
snojunkie's Avatar
Thanks for the info, do you know if the use of Locktite is recommended , and if so which strength?
post #4 of 10 (permalink) Old 08-12-2018, 09:02 AM
Blue. Not red. It's not in the manual, but its not going to hurt either. Me, I would do it. These bolts have backed out on a few pple.
RICZ likes this.
2016 Victory Magnum
Lloydz air filter
Ragin Cajun slipons
PowerVision CX
Tenax is offline
post #5 of 10 (permalink) Old 08-12-2018, 12:22 PM Thread Starter
snojunkie's Avatar
I am now 1 of "those" people .
post #6 of 10 (permalink) Old 08-12-2018, 12:36 PM
Well that just sucks. The theory is some bikes they were never torqued properly by the factory (or dealer of course if post tire change).
2016 Victory Magnum
Lloydz air filter
Ragin Cajun slipons
PowerVision CX
Tenax is offline
post #7 of 10 (permalink) Old 08-12-2018, 01:36 PM
djh3's Avatar
Checked manual. 71 lb is what diagram says. Locktite and I was taught blue if steel into aluminum, steel to steel red. The hub bolt should be a self locking nut.
RICZ and snojunkie like this.
djh3 is offline
post #8 of 10 (permalink) Old 08-12-2018, 06:49 PM
Correct it is 71 ft lb torqued in a star pattern. Blue loctite won't hurt.
visionjohnny and snojunkie like this.
post #9 of 10 (permalink) Old 08-13-2018, 05:33 AM
depot picker's Avatar
If you are going to be doing this stuff you need a service manual. There is a link for free downloads in here somewhere.
depot picker is offline
post #10 of 10 (permalink) Old 08-13-2018, 10:11 PM
djh3's Avatar
+1 on the service manual. Far as I know all the X bikes are same from start to finish.
djh3 is offline
