abs light came on this morning - Victory Forums - Victory Motorcycle Forum
 5Likes
post #1 of 18 (permalink) Old 08-14-2018, 04:58 AM Thread Starter
Default abs light came on this morning
Half way to work about 7 miles into the trip the abs light came on.
I know I'm fat but that's just rude.
Not sure procedure on checking that. I assume something in service manual. Hate to think I messed something up doing the rear wheel but I've put plenty of miles on after that so this seems very random.
post #2 of 18 (permalink) Old 08-14-2018, 05:38 AM
BP6666VR's Avatar
Easy to check,
1 Find the chapter in the servuce manual
2 Take out the proximity switch
See if it dammaged
3 Space it as per speck given in the manual
4 Ride again .... For 10 meter
If that doesn't work then you need a new ABS cable, there 160 usd or something like that ... I bought 2 , coz better have 1 stock ....
I cannot believe how many people have broken this cable ... I think 5 or 8 vics & indians here ... But there are only 25 sold in total, so tbat is RUBBISH quality ....
Andre using TaPaTaLk
Cross Country Tour 2014 [B]
BP6666VR is offline
post #3 of 18 (permalink) Old 08-14-2018, 06:24 AM
depot picker's Avatar
I donít believe they are all broken. Iíve had a few incidents of persistent ABS light. It always came down to adjustment or dirty sensor or ring.
depot picker is offline
post #4 of 18 (permalink) Old 08-14-2018, 08:27 AM Thread Starter
I'm hoping just dirt. It only takes ten meters for it to shut off if it's good?
post #5 of 18 (permalink) Old 08-14-2018, 01:30 PM
That sounds about right. Basically once I'm rolling for a few secs mine goes out
2016 Victory Magnum
Lloydz air filter
Ragin Cajun slipons
PowerVision CX
Tenax is offline
post #6 of 18 (permalink) Old 08-14-2018, 04:57 PM Thread Starter
It was on the whole ride home from work. Boo. I'll look at it tomorrow when bike is cool. Rain day.
post #7 of 18 (permalink) Old 08-14-2018, 06:10 PM
Itís speed. 5 or 10 mph .
Chattanooga Mark likes this.
post #8 of 18 (permalink) Old 08-16-2018, 06:44 PM
rainman123's Avatar
When my abs light came on a couple years ago it was my abs relay that was bad
2012 crossroad
08 r3t traded for xr
06 rocket classic totaled
98 t-bird traded for rocket
73 sportster sold
72 honda 350 long gone
06 rocket3 classic
rainman123 is offline
post #9 of 18 (permalink) Old 08-19-2018, 08:32 PM Thread Starter
Trying to find large enough feeler gauges just to check the clearance isn't easy. I did read with googling that setting it towards the far end of spec is better. Also read that rear wheel adjustment can cause this. Planing to recheck the wheel and belt anyway so will see if that is it.
BP6666VR likes this.
post #10 of 18 (permalink) Old 08-19-2018, 08:38 PM
BP6666VR's Avatar
Could you measure a washer if that is the same gap you need ? I forgot the minimum & maximum gap, yes i did about the maximum gap also
BP6666VR is offline
