Broken fuel pump nipple repair - Victory Forums - Victory Motorcycle Forum
 23Likes
post #1 of 12 (permalink) Old 09-27-2018, 11:45 PM Thread Starter
Default Broken fuel pump nipple repair
Some guys on other sites that I frequent, are wanting to see my repair for a broken fuel pump nipple, so here goes.
First, I fatherly lecture as how to prevent this. The manual says when removing the tank, disconnect the fuel line at the lower end. Big mistake IMO. I find I have much more control over what the line is doing when I disconnect it from the top. The nipple breaks because side pressure is applied to the hose when it is connected to the pump and the tank is being lowered.
Now for the directions for the repair.........
1. Obtain a piece of 1/4" steel tubing - aluminum will do if steel is not available. It's sold by the foot and one foot will be more than enough.
2. With the tank angled so the remaining nipple is pointing downward, so nothing gets into the pump, drill the hole in the nipple with a bit that will provide an interference (friction) fit.
3. Do the same with the broken off piece.
4. Measure the depth of the hole in the pump part of the nipple.
5. Measure the length of the broken off part.
6. Cut the tubing to the two lengths added together. It helps to grind a taper on the end of the tubing.
7. Gently tap the tubing into the broken piece until it is flush with the top end of it. It could help to put some adhesive on the tubing and/or in the hole.
8. Place some adhesive like Super Glue on the two broken parts and tap the tubing into the pump, minding the orientation so they mate and the glue bonds.
You are done.
post #2 of 12 (permalink) Old 09-28-2018, 05:10 AM
It sucks that you had to do this, but because of it we all benefit. Thanks for sharing.
S&S Cams, Lloydz filter & ATS +5, PCV, UD pulley, Alto Red Eagle clutch pack
Madstad Windshield, 5000K HID, TriOvals, Memphis Shields wings
JVC KD-X33MBS, PBR300X4, Polk DB6502, DaytonAudio ND140-4 rear
HyperLites, LED driving lights, hydraulic clutch, Ultimate seat
post #3 of 12 (permalink) Old 09-28-2018, 05:29 AM
BP6666VR's Avatar
ALSOOOOO to add to this amaizing repair .... You can buy the fuel nipple on the tank side , so please remove the tank nipple and leave the engine nipple , exactly like RICZ says
NO wayyyyy you can buy the fuel nipple on the right hand engine side, impossible task ...
DORMAN 11.8 on the tank side ... no size on the engine size ...
RICZ you are the man of fixing this ... awsome
Andre using TaPaTaLk
TNXR likes this.
Cross Country Tour 2014 [B]
BP6666VR is offline
post #4 of 12 (permalink) Old 09-28-2018, 05:53 AM
TNXR's Avatar
I've had my tank off twice now by following the manual with no problems yet but I cringed thinking the worst would happen both times.
2011 Cross Roads Sunset Red
TNXR is offline
post #5 of 12 (permalink) Old 09-28-2018, 06:12 AM
For years, I took my tank off by removing the fuel line from the engine. Last time, however, I removed it from the tank instead and quite frankly I thought it was easier.
post #6 of 12 (permalink) Old 09-28-2018, 06:45 AM
depot picker's Avatar
Ha d my tank off many times.the Xct manual says to disconnect it at the tank. No problems.
depot picker is offline
post #7 of 12 (permalink) Old 09-28-2018, 09:56 AM
There's that and, well, you like showing off your nipple.
Thank you, we all needed to see it again.
broggyr and yago20 like this.
All the best,
Mark
www.bikersforchrist.org
"That's a beautiful Victory!"
"Thank you."
"Who makes it?"
"No one."
Chattanooga Mark is offline
post #8 of 12 (permalink) Old 09-28-2018, 10:45 AM
Yeah the manual says tank so that is what I plan on doing soon.
Thanks for the write up it should be sticky here.
post #9 of 12 (permalink) Old 04-17-2019, 10:17 PM
Hali Hammer's Avatar
Hey Ricz...had a little issue last night, and broke my fuel pump nipple...found this thread, and followed your instructions, and it went smooth..i did add Gas resistant Joint/Gasket maker to the tube, before I slid it into the fuel pump..and used JB weld for the epoxy of the 2 pieces..and it worked great..let it cure 100% tonight, and put it back together tomorrow for the big test..if it works, and I think it will, you saved me over $600Cdn..Just wanted to say Thanks, for sharing ..!
RICZ and Jakvis like this.
2011 Hammer S & 2012 Cross Country
Hali Hammer is offline
post #10 of 12 (permalink) Old 04-17-2019, 11:09 PM Thread Starter
Thanks for the thanks. I'm all about saving money by spending the least I can. And I wasn't going to hand over to Polaris hundred$ for their poor design work. I have already done some work arounds on my Spyder, saving about $200 and I just got it about a month ago.
vindex1963 likes this.
