audio upgrades - Victory Forums - Victory Motorcycle Forum
 4Likes
post #1 of 31 (permalink) Old 11-03-2018, 06:42 PM Thread Starter
psychodiablo's Avatar
Send a message via AIM to psychodiablo
Unhappy audio upgrades
how in all that is holy do you mount the speaker baffles to the back of the speakers. got the addapter rings mounted with the speakers then mounted to them. i also got the recommended rockford fosgate amp T400x4ADB. i also got wireing kit with bracket. but when i get to installing the bracket it says on frekn package it is for pbr400x4d. dam it what do i frekn do now.
Leesville Louisiana. 2012 cross country, speedo upgrade,forged engine guard,touring sheild, tri oval pipes, Lloyds gen 3 fuel controler, Lloyds highflow airfilter. Lloyds timeing wheel, msd coils,Lloyds 8.2 mm red wires,tank lift/spacers,tank wings,side cover scoops,audio input cord,drivers back rest, 2in pull back bars,polk 5.25 speakers,XC Mag baffles,rockford fosgate pbr400x4 amp,lower wind deflectors,sylvainia ZXE Gold h-11 headlights. rivco hiden hitch. IDMW,FYIYDLMOMB.
psychodiablo is offline
post #2 of 31 (permalink) Old 11-04-2018, 12:30 AM Thread Starter
i went and fuked up the i pod cord now i need another new cord. whats the part number for the cord with the lighting connector that plugs into the bikes harness.
post #3 of 31 (permalink) Old 11-04-2018, 09:26 AM
Not sure they run $50-100 on Facebook sale group for iPod cable. Be more from Vic if they let you buy it. Probably one of those parts that needs VIN verification.
post #4 of 31 (permalink) Old 11-04-2018, 09:29 AM
klementa's Avatar
Which bike do you have? If you have the full size head unit in lieu of 8ball getting the T400 in the fairing won’t be easy. Did you buy a Bluetooth adapter also? You don’t the aux cord if you did. The jl audio is perfect to add to your amp (see below). If you want to keep your aux connection or if you have the 32 pin apple connection their are other options too. I have done several of these.. the 5 1/4 speaker will sound better in the fairing with more bass if you leave the stock enclosure pods in place instead of adding 6 1/2’s. They have to mount from the back behind the fairing if you use the 6 1/2’s and remove the enclosure.
Love all motorcycles but Vic is my fave.
Current bike is a 16’ Magnum with Vance and Hines exhaust, full Rockford Fosgate audio system replacing the meek stock system (Rockford TM400x4 amp, TMS5 in fairing and TMS69 in Vic audio lids).
Dynojet PVCX, Lloydz intake filter and throttle ring with Fuel moto/Craig Bennett fine tune
Mods to come - Cams? See what the tune does...
klementa is offline
post #5 of 31 (permalink) Old 11-04-2018, 09:36 AM
I'm still trying to understand the need for bass on a motorcycle. My other bike has excellent base with amp and such but comparing that to the Vic cruising down the highway it really doesn't matter.
post #6 of 31 (permalink) Old 11-04-2018, 09:37 AM
klementa's Avatar
In the marketplace section someone is selling the aux/iPod cord for you.. hit them up.
https://www.victoryforums.com/13-mot...xct-parts.html
klementa is offline
post #7 of 31 (permalink) Old 11-04-2018, 11:09 AM Thread Starter
look at the signiture. the baffles i am talking about are the boom mat ones made of foam. how do i mount them to the speakers.
post #8 of 31 (permalink) Old 11-04-2018, 11:37 AM
some guy over on vogt need a ipod cable and called these guys and they had one
https://www.radiosound.com/products.html#ntouch-radio
post #9 of 31 (permalink) Old 11-04-2018, 12:01 PM
klementa's Avatar
Trying to help you and you tell me to “look at the signature”... ? Good luck.
klementa is offline
post #10 of 31 (permalink) Old 11-04-2018, 12:07 PM
klementa's Avatar
It’s more about “loud” to hear over wind noise. All bass is gone after 20mph. The 5 1/4 will retain more output with the OEM sealed enclosure than using a back mounted 6 1/2 that’s free air and farther away from the grille.
Bueller likes this.
klementa is offline
