What's Going On? - Victory Forums - Victory Motorcycle Forum
 1Likes
  • 1 Post By djh3
post #1 of 10 (permalink) Old 11-04-2018, 04:01 PM Thread Starter
Default What's Going On?
I have a 2014 CCT. When starting the bike cold in neutral the neutral indicator (N) shows. When I turn the bike off, the oil lamp indicator goes out immediately. After riding for about 5 miles or more, when I put it in neutral, no neutral indicator light shows. When this happens, when I cut the motor off using key or kill switch, the oil light lamp stays on for a few seconds, then goes out. This has been happening for about 3 months. Oil level is good. Everything else works fine. Any ideas why this is happening? Any suggestions or fixes will be appreciated. Thanks
vw71blue is offline
post #2 of 10 (permalink) Old 11-05-2018, 12:54 PM
oil light sounds normal.
post #3 of 10 (permalink) Old 11-05-2018, 04:29 PM
Mine does it too. I chalk it up to "Normal Operation".
post #4 of 10 (permalink) Old 11-05-2018, 06:02 PM Thread Starter
Thanks for the comments. I can now rest a little easier.
vw71blue is offline
post #5 of 10 (permalink) Old 11-05-2018, 10:23 PM
djh3's Avatar
I only really trust the green neutral light. The one in dash that indicates gear is somehow connected thru the speed indication or something. Wont read neutral sitting still I think.
2013 XCT added Jan 2015
djh3 is offline
post #6 of 10 (permalink) Old 11-06-2018, 01:51 PM
If you have owners book read up on shifting. Don't remember what year it was but Vic changed something and when clutch is in there in no natural light like the old ones
post #7 of 10 (permalink) Old 11-07-2018, 04:14 PM
You have no green neutral N when in neutral?
post #8 of 10 (permalink) Old 11-08-2018, 05:03 PM Thread Starter
After the engine warms up, no neutral light. When the engine is cold, everything works fine.
vw71blue is offline
post #9 of 10 (permalink) Old 11-08-2018, 05:16 PM
Wow. That would concern me too but I guess if neutral still works then it's not an issue. My 2012 doesn't do that.
post #10 of 10 (permalink) Old 11-08-2018, 06:09 PM Thread Starter
I will have it checked at next service.
vw71blue is offline
