Accessory power switch option. - Victory Forums - Victory Motorcycle Forum
post #1 of 5 (permalink) Old 11-26-2018, 11:12 AM Thread Starter
Default Accessory power switch option.
So, I'd like to be able to run my stereo off battery for some length. Having the power switch on also means my factory light is on, which also drains the battery. Is there a way to have an "accessory" option at the key so I can not have the light on? Or are there better options for what I'm trying to do? Thanks!
2013 Suede Nuclear Sunset Cross Country
Vicbaggers Tarzanz handlebars
Thrush modded exhaust
Saddlebag rails
Avon grips and Avon shifter pegs
Kuryakyn Liberator highway pegs with stirrups
and much more
See this post for more details.
Wyckedjester is offline
post #2 of 5 (permalink) Old 11-26-2018, 12:08 PM
For your 2013 CC? If so, do you have the Victory/Scorpio Keyless Ignition mounted? If not, does turning the key to ACC give you that option? I have the keyless ignition so therefore lost the ACC option the original ignition key provided.
All the best,
Mark
www.bikersforchrist.org
"That's a beautiful Victory!"
"Thank you."
"Who makes it?"
"No one."
Chattanooga Mark is offline
post #3 of 5 (permalink) Old 11-26-2018, 12:22 PM
I don't mess with the ACC option but I seem to remember you have to push the key in to get it to turn to that position. My memory isn't what it used to be though so who knows...
post #4 of 5 (permalink) Old 11-26-2018, 12:49 PM Thread Starter
OHHHHH. I didn't even know that was there. I'll try that out in a few days when I get my bike back.
Saddlebag rails
and much more
post #5 of 5 (permalink) Old 11-27-2018, 01:55 PM
here is owners book you might want to read it
https://prdvehiclepubsdata001.blob.c...9924041r01.pdf
