Kuryakyn Saber Lights - rubbing normal? - Page 2 - Victory Forums - Victory Motorcycle Forum
 20Likes
post #11 of 27 (permalink) Old 12-02-2018, 11:10 AM
I added a pair of Hyper-Lights under the arms of the rear turn sigs where they are seen only from the rear. Vic and H-L made it easy; Vic provided a convenient hole in the underside of the arms for the wires and H-L included powerful double sided sticky tape to mount them. They are available in several modes - I got the ones that are running lights and go very bright when the brakes are applied, blinking for 5 seconds and then on steady. Great for getting the attention of approaching cars when I'm stopped at a traffic light. First pic, they're off / second, they're on. They are a lot brighter than the photo indicates and SUPER BRIGHT when the brakes are applied.
post #12 of 27 (permalink) Old 12-02-2018, 06:48 PM Thread Starter
Nice. Anything to get attention.
RICZ likes this.
post #13 of 27 (permalink) Old 12-03-2018, 07:49 AM
MonsterMash's Avatar
Installed the kuryakyn saber lights on the saddlebags. There is really only one way to do that with how they fit.
The top is getting rubbed raw by the lids on the saddlebags. It's not harmful to the lights and you can't see it when lids are closed.
Just curious if this is normal for these lights?
does it look anything like this?
if so, I sent these to Kury and they responded back with "we have had tons of installs with no issues. if you are getting rubbing like that on the cables, you should drill through the side of the saddlebags and make sure to seal it with silicone." they had no response for the rubbing on the top of the lights. these were only installed on the bike for a week. but because half of the LED's on the clutch side were out when i installed them, they did replace them free of charge.. i am debating on actually installing them again.
you got your jesus on the dashboard, the devil's under my hood. you're takin' down to legal, i'm pulling it up to no good.
god is your co-pilot, i let satan ride shotgun, you pay a toll to get to heaven, but on the road to hell there's none..... \m/ \m/
2010 Cross Roads
Navy - Its not just a job, its an adventure :)
MonsterMash is offline
post #14 of 27 (permalink) Old 12-03-2018, 07:55 AM Thread Starter
We have a winner!
Yes exactly like that but it's rubbed white across the top of both sides.
I don't care significantly because it isn't visible with the bags closed. I will try loosening the lids and see if I can wiggle them back a bit in the spring. Bike is done for the year they won't stop salting the roads here.
I actually read your post on a while back and as result of that I routed the wiring differently to avoid that issue. Did not remember you having the tops rub though.
post #15 of 27 (permalink) Old 12-03-2018, 08:06 AM
Bueller's Avatar
The lids are going to move. In fact Victory says if you take them off for any reason you should buy a new seal.
Chattanooga Mark likes this.
16 Magnum Midwest USA
Bueller is offline
post #16 of 27 (permalink) Old 12-03-2018, 08:42 AM Thread Starter
Well no one cares what Victory says anymore. Lol
They do move on the hinges because the close system isn't perfect but I wouldn't expect them to move front to back motion under normal use.
post #17 of 27 (permalink) Old 12-03-2018, 01:31 PM
Dusty Boots's Avatar
I installed mine at the beginning of the riding season and have since put on 35,000 km / 22,000 mi and no issuess with rubbing/chaffing.
Agreed with more visibility to the rear of bike.
2013 Victory XCT - SW Ontario
Stage 1 Victory Tri Oval kit, with EFI retune
Lloydz Timing Wheel (+4)
Quarter turn throttle ring
It's never too early to plan and never too late to go!
Dusty Boots is offline
post #18 of 27 (permalink) Old 12-03-2018, 04:56 PM
Originally Posted by Bueller View Post
The most beautiful XC bikes I have seen do not have those lights. I can understand why some people run them though.
I've been rear-ended on a bike... my biggest fear. I don't really care too much what they look like but I do like the way they look. Mine don't rub on the lids.
Sent from my SAMSUNG-SM-G935A using Tapatalk
SpecialK is offline
post #19 of 27 (permalink) Old 12-03-2018, 04:59 PM
Originally Posted by theja1 View Post
You could add a full size Ferris wheel....people only see what they look at. There is a reason 18-wheelers get rear ended.
Nothing you can do but pay attention to the ones coming behind you. If they arenít looking, they arenít looking.
Condoms prevent Minivans.
Sadly true. When I was rear-ended on my bike it was my best friend driving the car that hit me. He knew I was there, didn't know I'd stopped... I still want all the light I can get on the back (and front).
SpecialK is offline
post #20 of 27 (permalink) Old 12-03-2018, 08:21 PM Thread Starter
https://www.youtube.com/watch?v=lfcDeVeEqcU
That's very cool. Does the bike go crazy with that flasher? I've read old posts about not messing with the brake wiring because bike doesn't like it and things like cruise won't work.
