Brake Light Wiring for 2012 XC - Victory Forums - Victory Motorcycle Forum
 13Likes
post #1 of 36 (permalink) Old 03-10-2019, 07:53 PM Thread Starter
Default Brake Light Wiring for 2012 XC
Hello Forum,
I'm hoping that someone with more knowledge about the brake light wiring might be able to help me.
I recently purchased a Gear Brake Smart Brake Light Module that flashes the brake light when you start to slow down, either through direct brake pressure or down shifting. Unfortunately, I got a deal on the module because it's generic wiring and doesn't come with a XC wiring harness, so I'm trying to figure it out for myself.
I've already consulted the XR/XC/XCT service manual on page 19.7 to try and decipher the Tail Light Wiring Diagram, but it depicts a 6-pin lighting harness, instead of the 8-pin harness I have under my left side panel. (Maybe XRs have 6-pin?).
Anyway, for this module to work I need to find: 1) Ground, 2) 12 V Power, 3) Brake Input, 4) Light Output.
I've already connected Kuryakyn rear saddlebag lights to the harness under the left panel, so I'm hoping to connect this unit to make all of them flash as I'm slowing down.
If anyone can point me to the correct Pin Letters on the 8-pin connector, or wire-colors, it would be much appreciated.
Ride Safely!
2012 Victory Cross Country
Las Vegas, NV
LVJeff is offline
post #2 of 36 (permalink) Old 03-10-2019, 10:45 PM
Black is ground. To determine the others, use a test light and activate various circuits.
wspollack likes this.
post #3 of 36 (permalink) Old 03-10-2019, 11:32 PM Thread Starter
Thank you. I thought about that...I was just hoping someone might have a better wiring diagram available to them. ...but if not, I'll, use the tester light.
Las Vegas, NV
LVJeff is offline
post #4 of 36 (permalink) Old 03-11-2019, 07:55 AM
WeekendRider's Avatar
If you are referring to the unused 8-pin plug under the left side panel, that's for the trunk/tour pack. It will have everything you need but you'll need to find the wiring diagram for the trunk.
2013 XC Suede Nuclear Sunset
21" Conversion incl. ABS Module, Rear Shock and Forks
Lowered...a lot
RCX Slip-ons
Lloydz HPT Cams
Lloydz Air Filter
Lloydz Timing Gear +4
31 Tooth Drive Pulley
Southern Motorworx Tune: 118.08 HP - 114.97 Torque (before 31 tooth drive pulley)
WeekendRider is offline
post #5 of 36 (permalink) Old 03-11-2019, 09:03 AM Thread Starter
Oh, thank you, I guess I want to tap into the main brake wiring instead?? Can anyone point me in the right direction to find that?
Las Vegas, NV
LVJeff is offline
post #6 of 36 (permalink) Old 03-11-2019, 09:06 AM Thread Starter
...or will tapping into the brake wire there, at the trunk plug, still activate the main brake light?
Las Vegas, NV
LVJeff is offline
post #7 of 36 (permalink) Old 03-11-2019, 09:36 AM
The trunk also has a full tail/brake light, so that trunk plug is essentially tapping into the main brake circuits, as long as you can find the right wires.
[EDIT] Page 19.31 in the service manual has the plug and pinout info.
S&S Cams, Lloydz filter & ATS +5, PCV, UD pulley, Alto Red Eagle clutch pack
Madstad Windshield, 5000K HID, TriOvals, Memphis Shields wings
JVC KD-X33MBS, PBR300X4, Polk DB6502, DaytonAudio ND140-4 rear
HyperLites, LED driving lights, hydraulic clutch, Ultimate seat
post #8 of 36 (permalink) Old 03-11-2019, 11:03 AM
When I had wiring concerns - I was hooking up a gear indicator and needed to know which were the speed sensor and tach sensor wires - I went to my dealer who pulled the shop's shop manual for my bike and it contained a HUGE foldout wiring schematic that even showed the connectors and pins. That was all the help I needed. That will work for you too, if a test light doesn't reveal that.
post #9 of 36 (permalink) Old 03-11-2019, 03:52 PM
Here is the info for the trunk plug:
Lowered...a lot
RCX Slip-ons
Lloydz HPT Cams
Lloydz Air Filter
post #10 of 36 (permalink) Old 03-11-2019, 04:14 PM Thread Starter
EUREKA!
Thank you WeekendRider!
Las Vegas, NV
LVJeff is offline
Similar Threads
Thread Thread Starter Forum Replies Last Post
Tail light / brake light OUT LILMAGS500 Victory Tech and Performance Section 89 11-13-2016 06:22 PM
2009 Kingpin Tail Light, brake light and plate light Kingpin2009 Victory Tech and Performance Section 4 06-11-2015 01:25 PM
Led brake light problems on my 2012 hammer theblade88 Victory Hammer Forum 4 05-20-2014 10:44 AM
Vegas wiring help - brake light Ndmba2010 Victory General Discussion 9 03-17-2014 11:30 PM
extra brake light on XC magman Victory Cross Country and Cross Roads 25 05-10-2013 08:25 AM
