Air intake location - Page 2 - Victory Forums - Victory Motorcycle Forum
 7Likes
post #11 of 18 (permalink) Old 03-19-2019, 01:46 PM Thread Starter
You only get 10" of rain a year on average. Unless you find yourself riding in the rain a lot; I wouldn't even worry about it. It's not likely the rain is going to get in there with the fairing in the way anyway.
You can gain 8 hp by removing that rubber gasket and unplugging the O2 sensors on a bone stock bike. By unplugging the sensors the ECM goes into a default mode that richens the AFR a bit to be on the safe side. It doesn't know they were unplugged. All it knows is it's not getting a signal from them.
Obviously this is a temporary measure until a tune can be installed and/or other performance parts like cams, air filter, and freer flowing exhaust.
Well here comes an age old question...
I bought the bike used and the previous owner had the trioval exhaust installed at the dealer before he ever rode it away.
Would a tune have been done by the dealer or should I even worry about that until I get a Lloyd's air filter?
2013 Cross Country, Nuclear Sunset Orange
Trioval Exhaust
Arlen Ness Deep Cut Grips
Orange13 is offline
post #12 of 18 (permalink) Old 03-19-2019, 02:00 PM
The Tri-Oval's come with a tune and a freer flowing air filter. The tune is what Victory/Polaris calls a stage one. Chances are very good they installed the tune along with the air filter.
What are your plans for a tune or is there any? Do you plan on installing cams?
If you plan on installing cams, a tune, and a Lloydz air filter then you will want to do that all at one time.
post #13 of 18 (permalink) Old 03-19-2019, 02:29 PM Thread Starter
I do plan on installing cams down the road and I figured I would do the intake at the same time so I would only have to get it tuned once. Would removing that rubber piece now effect the tune that Is on it?
Trioval Exhaust
Orange13 is offline
post #14 of 18 (permalink) Old 03-19-2019, 08:34 PM
Probably not. Can you see if the O2 sensors have been disconnected. You don't have to unplug them but if you pull the rubber gasket and find it pings or runs hot; you may want to.
post #15 of 18 (permalink) Old 03-19-2019, 08:45 PM Thread Starter
Im pretty sure they are still connected. There is some white connector disconnected though. Im the middle of the picture. O2 sensor is the long black 1 to the right of it correct?
Trioval Exhaust
Orange13 is offline
post #16 of 18 (permalink) Old 03-19-2019, 10:38 PM
I'm not sure what the 3 prong white connector is but your O2 connector as shown is obviously still connected. There should be another one on the front exhaust close to the exhaust port.
post #17 of 18 (permalink) Old 03-21-2019, 03:12 AM
GatorJoe's Avatar
Get Quite a bit of Rain in North Florida and had no problems with the Rubber Removed for 80,000 Miles ..
BBob likes this.
2017 Indian Chieftain Dark Horse/2005 Dyna Super Glide
GatorJoe is offline
post #18 of 18 (permalink) Old 03-21-2019, 08:11 AM Thread Starter
Good to hear GatorJoe. I'll probably go ahead and do this next week then
GatorJoe likes this.
Trioval Exhaust
Orange13 is offline
Similar Threads
Thread Thread Starter Forum Replies Last Post
Intake thirdgearcustoms intake and PCV installed Chezgetssome Victory Hammer Forum 11 05-15-2017 07:56 AM
Outside air temp sensor location JackPt Victory Cross Country and Cross Roads 7 03-31-2015 05:39 PM
K&N air filter , Oem air filter, oem intake side covers. (Alberta, Canada) Rootzee Motorcycle Parts For Sale / Wanted 2 11-23-2014 12:34 AM
