Air intake location - Victory Forums - Victory Motorcycle Forum
 7Likes
post #1 of 18 (permalink) Old 03-18-2019, 11:49 AM Thread Starter
Default Air intake location
I know that the filter is under the gas tank, but where does it get the air from? I've seen a video of replacing the filter and seen a large gap to the front of the frame but couldn't find a gap to let the air in.
Orange13 is offline
post #2 of 18 (permalink) Old 03-18-2019, 12:59 PM
From under the tank. There's sufficient space for adequate air flow. Buy one of my wonderful laydown license brackets and you'll think your bike is supercharged.
vindex1963 and broggyr like this.
post #3 of 18 (permalink) Old 03-18-2019, 11:46 PM Thread Starter
But how does the air flow get to the filter? Sorry if the question seems dumb but it looks like the rubber around the factory filter is preventing any air between the tank and frame
2013 Cross Country, Nuclear Sunset Orange
Trioval Exhaust
Arlen Ness Deep Cut Grips
Orange13 is offline
post #4 of 18 (permalink) Old 03-19-2019, 06:14 AM
It comes in from behind the rubber thing. Some of us with aftermarket air filters have removed the rubber piece altogether.
GatorJoe likes this.
S&S Cams, Lloydz filter & ATS +5, PCV, UD pulley, Alto Red Eagle clutch pack
Madstad Windshield, 5000K HID, TriOvals, Memphis Shields wings
JVC KD-X33MBS, PBR300X4, Polk DB6502, DaytonAudio ND140-4 rear
HyperLites, LED driving lights, hydraulic clutch, Ultimate seat
post #5 of 18 (permalink) Old 03-19-2019, 06:55 AM
vindex1963's Avatar
I've heard from unreliable sources that your gas mileage will also double.
NAB likes this.
1/4 turn throttle ring
Tank riser
VM-1 DR cams
Timing wheel +4
Lloydz high-flow air cleaner
Bassani baffled OEM mufflers
PC-V 118hp 116tq
vindex1963 is offline
post #6 of 18 (permalink) Old 03-19-2019, 07:07 AM
It comes in from all around the filter under the tank but I think a large percentage of the air flows in from under the front of the gas tank.
Is that what you were asking?
post #7 of 18 (permalink) Old 03-19-2019, 10:21 AM Thread Starter
Yes that answers it. I just didn't think any air could get past that rubber thingy so I wasnt sure if it came through the frame or something
Trioval Exhaust
Orange13 is offline
post #8 of 18 (permalink) Old 03-19-2019, 11:02 AM
The rubber thingy is for water diversion.
post #9 of 18 (permalink) Old 03-19-2019, 11:08 AM Thread Starter
Gotcha. I'll probably wait till I get a new intake to remove that
Trioval Exhaust
Orange13 is offline
post #10 of 18 (permalink) Old 03-19-2019, 01:19 PM
You only get 10" of rain a year on average. Unless you find yourself riding in the rain a lot; I wouldn't even worry about it. It's not likely the rain is going to get in there with the fairing in the way anyway.
You can gain 8 hp by removing that rubber gasket and unplugging the O2 sensors on a bone stock bike. By unplugging the sensors the ECM goes into a default mode that richens the AFR a bit to be on the safe side. It doesn't know they were unplugged. All it knows is it's not getting a signal from them.
Obviously this is a temporary measure until a tune can be installed and/or other performance parts like cams, air filter, and freer flowing exhaust.
Similar Threads
Thread Thread Starter Forum Replies Last Post
Intake thirdgearcustoms intake and PCV installed Chezgetssome Victory Hammer Forum 11 05-15-2017 07:56 AM
Outside air temp sensor location JackPt Victory Cross Country and Cross Roads 7 03-31-2015 05:39 PM
K&N air filter , Oem air filter, oem intake side covers. (Alberta, Canada) Rootzee Motorcycle Parts For Sale / Wanted 2 11-23-2014 12:34 AM
