2011 XR Check Engine Light - Victory Forums - Victory Motorcycle Forum
 11Likes
post #1 of 12 (permalink) Old 03-24-2019, 03:49 PM Thread Starter
specialidiot's Avatar
Default 2011 XR Check Engine Light
Greetings riders, I have A 2011 XR, 15,000 miles with exhaust and download. Other than the infamous pulley chirp I've not had any problems at all. On today's ride the check engine light came one a couple of times. Here are the codes:
error code 1
SPN 520193
FMI 7
error code 0
SPN 168
FMI 3
Is it possible it is battery related? I'm on my original battery, and it struggled to start me a couple of weeks ago after the bike sat about 3 weeks.
Any info would be appreciated.
2011 Cross Roads
specialidiot is offline
post #2 of 12 (permalink) Old 03-24-2019, 04:26 PM
Tony.v's Avatar
Very high probability it's the battery. Your lucky to get 4-5 years out of a battery
2017 Victory Vision Gloss black
1996 Kawasaki Voyager XII (sold)
1981 Kawasaki GPz550 (sold)
Tony.v is offline
post #3 of 12 (permalink) Old 03-24-2019, 10:28 PM
djh3's Avatar
the 168 code says: System Power (battery potential/ power input) Condition: Voltage too high
Now the reason it might be high is because the battery is going bad and the voltage regulator is trying to catch up. The other code I have not been able to find yet.
There's an app you can download from the Play Store called Indian Diagnostics. Supposedly it lists the codes which are identical to Victory ( both Polaris bikes). Check your main fuse connections located next to your battery and while you're at it the battery connections to make sure they're tight.
From another Victory site.
2013 XCT added Jan 2015
djh3 is offline
post #4 of 12 (permalink) Old 03-24-2019, 10:46 PM Thread Starter
thanks for the replies. I guess I'm kind of relieved that its probably the battery as I suspected. That said I only have 6 weeks left of my TX riding season before I head north. Any chance I'm doing any damage to the electrical system if I run it until it goes, if it does by mid-May? I'd rather get the battery when I return in the fall.
nomadsmg likes this.
2011 Cross Roads
post #5 of 12 (permalink) Old 03-24-2019, 11:09 PM
Why not get a new battery now and put an automatic trickle charger on it until you return to it? There are parasites that are draining the battery when the bike sits. And a battery loses charge at 10% / month normally. Why cheap out not buying a $100 battery on a $8000 bike? Makes no sense.
nomadsmg and BP6666VR like this.
post #6 of 12 (permalink) Old 03-24-2019, 11:14 PM Thread Starter
It's not cheaping out..... I'd rather buy the new battery when I return than buy one now and let it sit for 6 months, chewing up the warranty. I can put a trickle charger on the one I have if the 10% concerns you but I does start every few days when I use it. I'm just wondering if the overvoltage is causing problems. Then i would buy the battery now.
Oh and $8,000? Where would you like it delivered to?
2011 Cross Roads
post #7 of 12 (permalink) Old 03-24-2019, 11:19 PM
I just sold my 2010 XR for $8K and the buyer was ecstatic. Overvoltage can cost you the regulator too. You asked for help - I tried to help. Good luck.
post #8 of 12 (permalink) Old 03-25-2019, 01:40 AM
BP6666VR's Avatar
I agree, bad battery before storrage is just as bad as a bad battery riding the bike ... Good info right there RICZ
Andre using TaPaTaLk
Cross Country Tour 2014 [B]
BP6666VR is offline
post #9 of 12 (permalink) Old 03-25-2019, 03:24 AM
I wouldn't risk it. I'd get the new battery now and be done with it or risk damage to electronics. Victory's are well known to be fickle about dying and lithium batteries.
BBob is online now
post #10 of 12 (permalink) Old 03-25-2019, 06:06 AM Thread Starter
Thank you everyone for your advice. I will replace the battery.
I did ask for help, not a lecture. 12000 posts doesn't give anyone the right to talk down to someone.
2011 Cross Roads
Similar Threads
Thread Thread Starter Forum Replies Last Post
2011 Hammer S Check engine light minikojak Victory Tech and Performance Section 3 07-15-2011 11:55 AM
Check Engine Light randall.mercer Victory Tech and Performance Section 3 05-18-2011 02:53 PM
Check Engine Light Domino Victory Tech and Performance Section 14 05-18-2011 11:05 AM
Check Engine light???? Black&blue_8ball Victory Tech and Performance Section 2 12-19-2009 10:01 AM
New Bike......but he check engine light is on? 07Hammer Victory Hammer Forum 0 04-04-2009 01:23 PM
