Loyd's Timing gear set - Victory Forums - Victory Motorcycle Forum
 1Likes
  • 1 Post By RoteBaron
post #1 of 5 (permalink) Old 03-30-2019, 04:19 PM Thread Starter
Default Loyd's Timing gear set
At 4400 ft above sea level...was wondering what advance or reteard have those members at similar elevations set their timing gear for best performance. Not mechanical by any means, but can follow the simple instructions given on various sites. Thanks in advance...Spring is on the way..hang on all you Northern folks.
Hammy
Reno NV
Hammy
2016 Victory Cross Country
Reno Nevada
Renorider is offline
post #2 of 5 (permalink) Old 03-30-2019, 04:31 PM Thread Starter
91 octane normally...and yes there is ethanol round here..
Hammy
Reno Nevada
post #3 of 5 (permalink) Old 03-30-2019, 05:17 PM
RoteBaron's Avatar
Default Timing wheel set
All bikes tend to respond a little different. With that said I have mine on a '13 Vision set at ~+3. I've ridden it at 9000ft down to sea level with not issues. Not sure about your bike but set it at +3 or +4 and see how it runs. Some guys run them at much more than that and you can experiment. Just cut it back if (when) it starts pinging from too much advance. OBTW I always run 91 octane in mine. LMYR
Chattanooga Mark likes this.
Long may you ride!
RB
2013 Vision Sunset Red
Lloydz Timing wheel @ 3deg
Victory High Flow Air Filter
2017 Highball - Suede Nuclear Sunset Orange
RoteBaron is offline
post #4 of 5 (permalink) Old 03-30-2019, 06:05 PM Thread Starter
Thanx RoteBaron good place to start.
Hammy
Reno Nevada
post #5 of 5 (permalink) Old 03-31-2019, 11:09 AM
MLR1's Avatar
S.E. Idaho @ 4600+, so close in elevation. I run my XR at +4. Started the Vision there, but need to back it down to +3.
2010 Cross Roads, Midnight Cherry, PCV, LSC cams, Lloydz filter, ADJ timing wheel @+4, Home built mufflers....
2009 Vision Tour Premium, Black/Silver, PCV, Lloydz top filter, ADJ timing wheel @+4, Home built mufflers....
2003 Vegas, Solar Red, PCIII, Home made TT, Ness Swept exhaust, Custom Luggage Rack.... (sold)
MLR1 is offline
Similar Threads
Thread Thread Starter Forum Replies Last Post
Timing gear mod Bullypack3 Victory Tech and Performance Section 29 10-19-2016 11:50 AM
Another timing gear thread but with photos vindex1963 Victory Tech and Performance Section 69 01-03-2016 12:08 PM
Timing Gear Rattus Victory Tech and Performance Section 15 09-12-2015 12:12 AM
Timing gear David1807 Victory Cross Country and Cross Roads 10 07-25-2015 09:50 PM
pcv/timing wheel, removing timing with pcv dtmmil Victory Tech and Performance Section 12 07-05-2014 11:13 AM
