Cruise Control problem after load isolator install - Victory Forums - Victory Motorcycle Forum
 4Likes
  • 1 Post By djh3
  • 1 Post By Vinish
  • 2 Post By NOEMTZ
post #1 of 6 (permalink) Old 04-10-2019, 06:31 PM Thread Starter
Default Cruise Control problem after load isolator install
Hi. Like everyone else, I've had cruise control issues after the bike gets wet. However, this time, my cruise control hasn't come back after several days with a dehumidifier blowing on it. Question for you folks more knowledgeable than I (that would be most of you)... I recently installed Custom Dynamic Bullet Billets on the front and rear, and I used their load isolator to get them to work properly. Could this have somehow affected the cruise control? Do any of you have an isolator on your bike? Did it affect your cruise control? Thanks for your input.
2010 Cross Country
2004 BMW K1200LT (Sold to a close friend)
1998 Kawasaki Vulcan (Sold)
2007 KTM 250 XCF-W
jmsnyder01 is offline
post #2 of 6 (permalink) Old 04-10-2019, 10:00 PM
djh3's Avatar
Bike is CAN buss. As such it can be a finiky b-atch. I added some small LED lights around by bag rails, run, turn and brake wired into the system. All was fine. This fall I added a hitch with a trailer light harness hook up. Light did funky things. I ended up needing to add a powered isolator. When you add lights if the system "sees" to much or too little resistance in circuit it "faults". So maybe depending on what circuit and where you have the add on lights drawing power it could be causing the cruise issue.
wspollack likes this.
2013 XCT added Jan 2015
djh3 is offline
post #3 of 6 (permalink) Old 04-10-2019, 10:48 PM
Would it be possible to temporarily remove or disconnect the lights and load isolator and see if the cruise starts working again?
TNXR likes this.
G'day,
Vinish
Our patriotic stable:
Red 2012 XCT (my bike for NC)
Vinish is offline
post #4 of 6 (permalink) Old 04-11-2019, 05:52 AM Thread Starter
I was hoping to hear from someone that they installed the isolator and it didnt affect their cruise. Absent that, bypassing the isolator is my next step. My propensity for soldering and shrink wrapping is going to work against me.
2010 Cross Country
2007 KTM 250 XCF-W
post #5 of 6 (permalink) Old 04-11-2019, 06:02 AM Thread Starter
This is what I was thinking. The Custom Dynamics isolator is powered, and I did connect my trailer harness to it. My plan is to bypass the isolator and see if the cruise comes back. Appreciate your input.
2010 Cross Country
2007 KTM 250 XCF-W
post #6 of 6 (permalink) Old 04-12-2019, 07:05 PM
NOEMTZ's Avatar
don’t use existing ground in Harness for add ons. Run to own ground elsewhere on frame. See if that helps.
visionjohnny and wspollack like this.
www.noemtz.com
NOEMTZ is offline
Similar Threads
Thread Thread Starter Forum Replies Last Post
Cruise Control/ Brake light Problem? rdeerx Victory Tech and Performance Section 30 12-27-2014 01:33 PM
Cruise Control Install - $800 Labor? Mokken Victory Cross Country and Cross Roads 85 05-14-2014 05:54 PM
Control of cruise control lmartin780 Victory Cross Country and Cross Roads 3 09-12-2013 02:52 PM
Cruise Control for a 2010 Crossroads install helipro Victory Tech and Performance Section 7 11-14-2011 04:36 AM
