Overheating - Victory Forums - Victory Motorcycle Forum
 26Likes
post #1 of 38 (permalink) Old 04-12-2019, 01:43 PM Thread Starter
JJKJR's Avatar
Default Overheating
Yesterday my 2014 XC overheated. In the 30,000 miles I've owned it, this has never happened before. I was stopped on the highway for a little over and hour for a helicopter to pick up a severely injured accident victim. Not knowing how long I was going to be stopped, I let my bike run 20-30 minutes before I shut it off. It stayed off for a bit more than a 1/2 hour before traffic started to move. When I started the bike it was hard to start and it wouldn't hold an idle. I kept it running by slightly opening the throttle. Once I started moving the bike ran well until I got home, when it ran rough once again and I was able to hear the "tick" of the lifters. I just came back from running it today and all is back to normal; normal idle and no lifter sound. I plan on running it again tomorrow to make sure all is good.
My question is to prevent overheating in the future should I have kept the bike running the entire time or should I have turned it off immediately? Or is there other suggestions that the community has to offer. Thanks in advance for your help.
2014 Havasu Red XC
2004 Black Suzuki Volusia
JJKJR is offline
post #2 of 38 (permalink) Old 04-12-2019, 01:54 PM
wspollack's Avatar
I'm not an engineer, never played one on TV, and I didn't even stay at a Holiday Inn Express lately. Still, I have owned two air/oil-cooled bikes -- an R850R for three years, and an XCT for five -- and in situations like that I always just shut the bike off right away. I can't see how running while not moving would do bikes like that any good, not to mention just generating heat on me (okay, that last bit would be a good thing, I suppose, if it were very cold out, and I wanted to keep warm).
In fact, I can remember a time or two, back in those Beemer days, when with stop-and-go traffic jams as the result of an accident, I would pull off on the shoulder, and contemplate the meaning of life for a while, until things cleared up. That is, I wouldn't even participate in the game of moving forward a couple of car lengths, wait another couple of minutes, rinse and repeat, but rather chose to wait, say, 15 minutes, off to the side.
If you're waiting at a RR crossing for a train to pass, do you keep the bike running? How about in a rural construction zone, where a temporary light has been installed, because a normally two-lane road has one lane closed for repairs, and the temp light is controlling alternating lines of cars? I turn off the bike in both situations -- you?
But that's me. Let the knowledgeable folks chime in.
half_crazy, DaveT and Prestaged like this.
Cheers,
Bill P.
wspollack is offline
post #3 of 38 (permalink) Old 04-12-2019, 02:03 PM Thread Starter
JJKJR's Avatar
Wspollak, years ago I was taught to always keep your vehicle running. Until yesterday, I always kept my bike running and they never overheated. I'm sure that I was lucky. As you mentioned in your post, because of the extreme heat (on me) I shut it off. I truly believe what you are telling me is correct and I will from now on immediately shut my bike off. I believe by running it for a while, then shutting it off it never was able to cool enough to run properly. Thanks for the sage advice.
wspollack likes this.
2014 Havasu Red XC
JJKJR is offline
post #4 of 38 (permalink) Old 04-12-2019, 03:14 PM
vindex1963's Avatar
All the times I've been caught in 110/115 degree stop and go traffic here in Phoenix and the Vic didn't complain one bit. 25 miles coming home from work in 110+ stop and go will test you.
Bigmike17 likes this.
1/4 turn throttle ring
Tank riser
VM-1 DR cams
Timing wheel +4
Lloydz high-flow air cleaner
Bassani baffled OEM mufflers
PC-V 118hp 116tq
vindex1963 is offline
post #5 of 38 (permalink) Old 04-12-2019, 04:02 PM
half_crazy's Avatar
Air cooled engine....
What cools the engine is air flowing over the cooling fins on the engine and through the oil cooler... If the bike is not moving there is no air passing over the cooling fins on the engine or through the oil cooler... do you think letting it run for 1/2 an hour without airflow is a wise thing to do?
Yes, you should leave the vehicle running IF IT HAS A WATER PUMP, A RADIATOR, AND A FAN PULLING AIR THROUGH THE RADIATOR.
2006 Victory Kingpin
half_crazy is offline
post #6 of 38 (permalink) Old 04-12-2019, 06:15 PM
Jakvis's Avatar
I think I would have shut off after about 4 or 5 minutes of non movement. You may have cooked your oil a little so an oil change wouldn't be a bad thing to do now.
BBob, half_crazy, DaveT and 2 others like this.
Current Stable: 2014 XC, Honda PCX 150, 125 SYM Havana.
Born in the deepest jungles of India, I was raised by a friendly bear, until I was kidnapped by a pack of unruly baboons who taught me the finer points of swing jazz, all the while being stalked by an incompetent python and an evil but mis-understood tiger... Ummm, wait a minute, that's the Jungle book, no I was raised just outside of St. Louis, But...in the deepest jungles of a middle class neighborhood .
Jakvis is offline
post #7 of 38 (permalink) Old 04-12-2019, 06:17 PM
If in fact you did overheat the engine and the oil in it; the next thing to do is to change the oil. Overheating can cause the oil to break down. Dino oil has a lower temp threshold that causes breakdown in the oil than synthetics. Most people run a semi-synthetic so some or most of the oil can be toast if it reached that threshold. This was a big issue when I used to ride Harley's since they get much hotter than Victory's. Back in the day we didn't have synthetic oil so it was even more of an issue.
https://www.finol.ie/news/engine-oil-breakdown/
I don't know if your oil reached the necessary temp to start breaking down but if you think it might have; it couldn't hurt to change the oil. If you did so recently then just change the oil and drain the filter. You could reuse the filter.
DaveT likes this.
post #8 of 38 (permalink) Old 04-12-2019, 06:39 PM
Tony.v's Avatar
In this case the kind of oil you use will be the info needed, 100% synthetic would hold up really well to that kind of heat where semi or just normal oil not so much.
2017 Victory Vision Gloss black
1996 Kawasaki Voyager XII (sold)
1981 Kawasaki GPz550 (sold)
Tony.v is offline
post #9 of 38 (permalink) Old 04-12-2019, 07:21 PM
Yeah that is what I always thought, but Victory recommends using semi Synthetic oil in their engine and claim that it makes it run cooler. I do run Semi Synthetic 20 X 40 in mine, but would prefer to run straight Synthetic. I have never accepted that Semi is cooler in a Vic, but just have not moved away from it yet. I have had no overheating problems so far in Texas summer days.
cal_105215 is offline
post #10 of 38 (permalink) Old 04-12-2019, 08:26 PM
BP6666VR's Avatar
I live in a REALLY hot humid place and i bought the following oil
SPECTRO semi synthetic, of course you can go with the 15W40 and for most people that is perfect
But i went for 20W50 due to the hot weather here .... i just started using it a few hundred kilometers so i cannot comment on how it holds up , but all the vic gurus like this oil so i bought it online
Andre using TaPaTaLk
Cross Country Tour 2014 [B]
BP6666VR is offline
Similar Threads
Thread Thread Starter Forum Replies Last Post
V92C Brakes Overheating. Mark Whisenant Victory V92C 59 08-08-2017 02:17 PM
Very Unusual Overheating Issue FL2016XCTowner Victory Cross Country and Cross Roads 50 03-23-2016 05:52 AM
Very unusual overheating issue FL2016XCTowner Victory Tech and Performance Section 3 03-15-2016 08:36 AM
Cross Country Tour overheating issues? pat0021 Victory Cross Country and Cross Roads 18 02-24-2012 01:43 PM
Overheating ahhhh.... HELP!!! Tenac Victory Tech and Performance Section 82 09-04-2011 12:08 AM
