Oil drain case threads almost gone... How to fix? - Victory Forums - Victory Motorcycle Forum
 34Likes
post #1 of 32 (permalink) Old 04-27-2019, 06:41 AM Thread Starter
smokier104's Avatar
Question Oil drain case threads almost gone... How to fix?
Greetings All,
Went to change the oil for the first time since acquiring Momma's 12 XR. The plug came out a little funny, loose, tight, loose, out. It did seem to make steady progress while un-threading. Drained the oil, the filter (OEM) was on GORILLA tight, ufda... (1/4 turn after contact is enough, Mr. Godzilla).
Anyway, while replacing the plug it went in fairly smoothly (am very cautious about threading, not cross-threading), however, the drain plug never got tight. (???) The plug looked fully seated but wouldn't get snug.
Took the drain bolt out and inspected it, the threads on the bolt are fine. However, there was a little bit of aluminum shaving from the case visible. Cleaned things up, gingerly re-inserted the oil drain plug until it was fully seated. Did not try to ‘snug’ it this time, just got it to where it was fully seated. Filled with oil, level is holding, no leaks, no spots under the ride, no seepage around plug.
That’s the background story. So, how does one fix this? Heli-coil’s (IMHO) are good for bolts that do not get used frequently. (Like an oil drain plug). Should the case be re-tapped the same size? Should the case be re-tapped up a size? (From metric to standard for example?). Has this happened to others? (What was their solution?) Is there a common fix for this?
Appreciate your constructive thoughts and input.
Ride safe,
Smokier
Momma's ride is a:
'12 Cross Roads Ruby Red
Bushtec Hitch and harness
PC-V
D&D Slips-ons
Thundervolt Red 8.2mm by Sumax
Eastern Iowa
smokier104 is offline
post #2 of 32 (permalink) Old 04-27-2019, 07:06 AM
depot picker's Avatar
I would retap it to see if that resolves it. It’s quick easy and cheap.
depot picker is offline
post #3 of 32 (permalink) Old 04-27-2019, 09:42 AM
vindex1963's Avatar
Ride safe,
Smokier
Heli-Coils use what's called an STI tap that oversize's it so when the coil is put in the plug size remains the same. I use a Honda drain plug, same size but it's fully threaded.
RICZ, visionjohnny and yago20 like this.
1/4 turn throttle ring
Tank riser
VM-1 DR cams
Timing wheel +4
Lloydz high-flow air cleaner
Bassani baffled OEM mufflers
PC-V 118hp 116tq
vindex1963 is online now
post #4 of 32 (permalink) Old 04-28-2019, 05:32 AM
I stripped my oil drain hole threads a few years ago(being ham-fisted ). I went to an Advanced Auto near me and purchased a magnetic drain plug slightly oversized form the stock plug(sorry I don't remember which plug I actually used). I gently & slowly ran a tap up though to match the new plug and have had no issues since and it doesn't leak a drop.
visionjohnny and BP6666VR like this.
post #5 of 32 (permalink) Old 04-28-2019, 11:45 AM
If it were me I wouldn't trust the old threads in the motor. Stupid but cheap for polaris to think a steel plug and aluminum would be a good mix.
post #6 of 32 (permalink) Old 04-28-2019, 06:35 PM
BP6666VR's Avatar
You are right, if you have a aluminium body and need to torque a steel plate or flange to it then normally from factory they put helicoils in there, so why this is not done on Oil Drain / Rims is beond me as these bolts has to be removed and put back all the time ...
Andre using TaPaTaLk
Cross Country Tour 2014 [B]
BP6666VR is offline
post #7 of 32 (permalink) Old 04-28-2019, 06:44 PM
Steel plug in aluminum pans on plenty of cars. People who think plugs need to be gorilla tight are the issue. The same people that put a filter on so you have to destroy it to get it back off.
post #8 of 32 (permalink) Old 04-28-2019, 08:57 PM
This 100%. Drain plugs and oil filters need to be snug, not tight.
But, your threads are already damaged so it’s a mute point.The experts at The Vic Shop recommend a Time Sert, not a Helicoil. They’ve posted on this exact issue many times. Look them up, follow their advise exactly and you’ll be fine.
All the best,
Mark
www.bikersforchrist.org
"That's a beautiful Victory!"
"Thank you."
"Who makes it?"
"No one."
Chattanooga Mark is offline
post #9 of 32 (permalink) Old 04-29-2019, 05:19 PM Thread Starter
smokier104's Avatar
Greetings ALl,
Thanks for the replies. Rylan at the Vic Shop did get back to me and has suggested the "Time Sert" solution. Momma's ride has an appointment with Rylan for that a Dyno tune of the PCV. Two birds, one trip.
Thanks again, ride safe!
Smokier
Chattanooga Mark and BP6666VR like this.
Momma's ride is a:
PC-V
D&D Slips-ons
Eastern Iowa
post #10 of 32 (permalink) Old 04-29-2019, 05:31 PM
What the heck is a time sert?
Similar Threads
Thread Thread Starter Forum Replies Last Post
Oil on crank case breather hose with S&S intake JR_DOG Victory Tech and Performance Section 11 05-03-2017 06:04 PM
stripped/crossed oil drain plug threads :( PaiN Victory Cross Country and Cross Roads 24 04-06-2016 08:21 PM
Proper Way To Fix Drain Plug visionjohnny Victory General Discussion 16 04-04-2016 11:37 AM
Oil leak from engine case? BigBlue Victory Cross Country and Cross Roads 18 08-17-2015 11:39 AM
Stripped oil drain plug threads whatcaneyedo Oil and Lube 34 06-07-2013 08:57 PM
