Squeaking/Chirping from Drive Belt - Victory Forums - Victory Motorcycle Forum
 11Likes
post #1 of 37 (permalink) Old 05-02-2019, 10:19 AM Thread Starter
Default Squeaking/Chirping from Drive Belt
The drive belt on my XCT is exhibiting a squeaking sound upon acceleration. This sounds like a very aggravated bird chirp. I know that this is a common occurrence but can someone remind me if this is typically caused by the belt being too tight or too loose? I plan to adjust the belt tension soon and just want to have an idea of the direction to adjust. Thanks.
G'day,
Vinish
Our patriotic stable:
Red 2012 XCT (my bike for NC)
Vinish is offline
post #2 of 37 (permalink) Old 05-02-2019, 11:08 AM
specialidiot's Avatar
nope you are doomed.
Actually my research showed there is a replacement drive pulley available - if you can find one. I bought one but haven't had it installed yet.
2011 Cross Roads
specialidiot is offline
post #3 of 37 (permalink) Old 05-02-2019, 11:09 AM
WeekendRider's Avatar
Usually it is due to the belt not being centered and rubbing on the side of the rear pulley.
2013 XC Suede Nuclear Sunset
21" Conversion incl. ABS Module, Rear Shock and Forks
Lowered...a lot
RCX Slip-ons
Lloydz HPT Cams
Lloydz Air Filter
Lloydz Timing Gear +4
31 Tooth Drive Pulley
Southern Motorworx Tune: 118.08 HP - 114.97 Torque (before 31 tooth drive pulley)
WeekendRider is offline
post #4 of 37 (permalink) Old 05-02-2019, 11:20 AM
Alignment instructions...
BBob likes this.
Lowered...a lot
RCX Slip-ons
Lloydz HPT Cams
Lloydz Air Filter
post #5 of 37 (permalink) Old 05-02-2019, 11:22 AM
Alignments by two different Victory shops within weeks had zero effect on my chirp.
2011 Cross Roads
post #6 of 37 (permalink) Old 05-02-2019, 11:57 AM
I never could completely adjust the chirp out of my XC so I used different products on the inside of the pulley or outside of the belt like soap, wax, teflon lube, etc. What worked best for me was a Teflon grease made for bicycles. It lasts 6 months to a year depending on how much I ride that bike which honestly hasn't been a lot for last year or so.
post #7 of 37 (permalink) Old 05-02-2019, 12:35 PM
SkInM4N's Avatar
Mine chirped whenever the belt got loose. I adjusted the tension and haven't had another instance since then. The alignment was fine before and fine after (as close to perfect as I could get it.)
"Trail is life..."
#rideyoureffingbike
2016 Victory CCT "Miss Pearl"
- Lloydz VFC
- Lloydz Air Filter
- Lloydz QTTR
- Taylor Thundervolt wires
- Victory Tri-Ovals (no baffles)
SkInM4N is offline
post #8 of 37 (permalink) Old 05-02-2019, 06:38 PM
Check alignment and tension. Squeaky under acceleration would be slipping belt imo. Don't go too tight though or you'll be replacing bearings like me thanks to prior owner.
SkInM4N likes this.
post #9 of 37 (permalink) Old 05-02-2019, 06:53 PM
My bike started chirping right after my first tire change. I could minimize it, but that was it. When it came for my next tire change, I took the wheel off myself. I rotated the pulley one hole and haven't had the chirping since.
SkInM4N likes this.
S&S Cams, Lloydz filter & ATS +5, PCV, UD pulley, Alto Red Eagle clutch pack
Madstad Windshield, 5000K HID, TriOvals, Memphis Shields wings
JVC KD-X33MBS, PBR300X4, Polk DB6502, DaytonAudio ND140-4 rear
HyperLites, LED driving lights, hydraulic clutch, Ultimate seat
post #10 of 37 (permalink) Old 05-02-2019, 07:20 PM
Tony.v's Avatar
Mine chirps on deceleration only when it's cold so I've just left it alone. Has anyone used a belt dressing on their belt like you would use in HVAC on fan belts?
2017 Victory Vision Gloss black
1996 Kawasaki Voyager XII (sold)
1981 Kawasaki GPz550 (sold)
Tony.v is offline
Similar Threads
Thread Thread Starter Forum Replies Last Post
Belt chirping like a Bitch in heat ! LILMAGS500 Victory Cross Country and Cross Roads 63 12-06-2015 08:38 PM
Chirping Belt - Tension, Cleaning, or Lube? KingpinRider Victory Kingpin Forum 16 10-19-2012 07:19 AM
Chirping Belt Fix BBob Victory Tech and Performance Section 33 02-01-2012 06:25 AM
Chirping/whistling noise Ranman Victory Cross Country and Cross Roads 14 04-16-2011 09:47 PM
06 vegas chirping noise under load 06vegasprem Victory Tech and Performance Section 3 07-06-2010 02:11 PM
