Starter problem when hot - Victory Forums - Victory Motorcycle Forum
 3Likes
  • 3 Post By EraserX33
post #1 of 3 (permalink) Old 05-19-2019, 02:39 PM Thread Starter
EraserX33's Avatar
Default Starter problem when hot
Last week picked up an issue where the starter struggled a little bit to crank the engine over, but it started and off I went. Stopped at my destination for about 15 mins, tried to restart and it would try to turn over but wouldn't completely turn over. 2 or three more attempts and it finally turned over and started. Sounded very much like a weak battery. A week later... everything checks out good, bike cranks over fine when cold, not so much when hot. I can ride the bike, shut it off, and it will crank right back up if I try immediately. However if I wait 10 or 15 mins it acts like it's dragging, like a weak battery. I assume the starter or solenoid are getting heat soaked and this is causing my issue. Cleaned all connections, new battery (it was time anyway), new breaker. Am I looking at a bad starter or solenoid... or both? Try the solenoid first since it's cheap and easy? If it ends up being the starter, anyone have a good link to pick one up and is there a remove/replace tutorial out there?
Thanks ahead for any help.
Darrell
Darrell,
2011 Cross Country, Blue, 1" drop, D&D's, 21", raked tree, RF amp and HCX 6.5's
EraserX33 is offline
post #2 of 3 (permalink) Old 05-19-2019, 07:15 PM
rojo154's Avatar
I think you hit the nail on the head. You are right on when you say the starter absorbs the motor heat while sitting as apposed to when the the bike is moving and being cooled. Only thing I would say is check the battery voltage and the battery and starter connections that they are tight. How old is the battery?? May want to get an amperage check.
rojo154 is offline
post #3 of 3 (permalink) Old 05-30-2019, 07:28 PM Thread Starter
EraserX33's Avatar
Replaced starter, problem gone.
Darrell,
Similar Threads
Thread Thread Starter Forum Replies Last Post
riding hot, hot, hot! Motor62 Victory General Discussion 13 07-14-2015 01:17 PM
New XC Tour - mistake ? HOT HOT ! 1ofeach Victory Cross Country and Cross Roads 35 04-06-2015 07:21 PM
Hot hot to the touch! 07PEARLJACKPOT Victory Tech and Performance Section 13 04-15-2011 01:21 AM
How Hot is Hot ! BradT Victory Tech and Performance Section 5 05-28-2010 01:11 AM
newbie looking for 07 starter problem answers aldee Rules and New Members Introductions 0 07-22-2009 12:52 PM
