02 Sensor harness repair/replacement - Victory Forums - Victory Motorcycle Forum
 12Likes
post #1 of 15 (permalink) Old 05-22-2019, 09:41 AM Thread Starter
SkInM4N's Avatar
Default 02 Sensor harness repair/replacement
I have searched for a thread about this and cannot locate one. I am not really strong in the electrical department so I need to reach out for advice.
[ATTACH]IMG_4372.JPG[/ATTACH]
Can i rebuild the connector? Do I replace the whole harness? I need some help. The O2 sensors have been unplugged since shortly after I bought the bike in 2017 and the rear jug was fine but the front one has corroded and when I installed the Llloydz VCF kit I wasn't able to install the O2 connector to the front harness because of this.
Skin
"Trail is life..."
#rideyoureffingbike
2016 Victory CCT "Miss Pearl"
- Lloydz VFC
- Lloydz Air Filter
- Lloydz QTTR
- Taylor Thundervolt wires
- Victory Tri-Ovals (no baffles)
SkInM4N is offline
post #2 of 15 (permalink) Old 05-22-2019, 10:46 AM
I'm wondering how the heck it got that corroded in OK. Crazy.
Are two of the posts completely gone? I'm wondering if there's a chemical that dissolves the corrosion like CRC does on mineral deposits but that won't do any good if the posts are gone. Maybe something that dissolves the crap that builds up on battery posts.
If so then a good flush with water followed by some compressed air. Wearing safety glasses of course. Don't want any of that to get in your eyes.
SkInM4N likes this.
post #3 of 15 (permalink) Old 05-22-2019, 10:54 AM Thread Starter
SkInM4N's Avatar
I was right along the same lines of what you're thinking but one of the posts is completely gone and another one may as well be. I am looking into options for fixes. I didn't cover the connector so it's my bad it got corroded. I ride year round so idk what they put on the roads but it did a number on this connection. Probably why my grip heaters got effed up and why now my horn quit working too.
Skin
BBob likes this.
"Trail is life..."
#rideyoureffingbike
- Lloydz VFC
- Lloydz Air Filter
- Lloydz QTTR
SkInM4N is offline
post #4 of 15 (permalink) Old 05-22-2019, 11:01 AM
In that case I'm thinking it might be possible to pull the remaining pins/posts out from the other side using that special tool electricians use for that then replace the posts and reassemble.
Replacing the entire harness would be a big job. Doable but big.
Yeah; must be something use on the roads there. Salt I guess but who knows what it mixes with.
These videos may help.
https://www.youtube.com/results?sear...cal+connectors
SkInM4N and CanuckRob like this.
post #5 of 15 (permalink) Old 05-22-2019, 12:49 PM Thread Starter
SkInM4N's Avatar
Well it's not THE fix but it is A fix (temporarily at least) for this issue. I fashioned an "extended male" piece which i put in the 02 bypass pieces which come with the Lloydz VFC...it gave it enough room to make contact with whats left of the female connector. I cleaned the connector up as best I could and slapped her back together. I am afraid to take it back apart to get a picture since it is holding (for now) and not throwing the sensor code for the front jug. I will update if anything changes.
Thanks for the assist BBob
Skin
BBob and CanuckRob like this.
"Trail is life..."
#rideyoureffingbike
- Lloydz VFC
- Lloydz Air Filter
- Lloydz QTTR
SkInM4N is offline
post #6 of 15 (permalink) Old 05-22-2019, 01:49 PM
An option may be just cutting off the connector and adding/splicing on a pigtail. I believe the 2016+ 4-wire O2 sensors use the same connectors as a Chevrolet LS1 motored engine does. You might be able to find both sides of those pigtails a little more easily. Soldier, add dielectric grease, and heat shrink the splices.
2016 Cross Country Tour, gloss black
Sent from my iPhone using Tapatalk app
SkInM4N likes this.
2016 Cross Country Tour - gloss black
Chuckz71 is offline
post #7 of 15 (permalink) Old 05-22-2019, 01:52 PM
Currently on eBay:
SkInM4N likes this.
Chuckz71 is offline
post #8 of 15 (permalink) Old 05-22-2019, 02:13 PM Thread Starter
SkInM4N's Avatar
Currently on eBay:
Definitely an option if my current "patch" doesn't hold. Thanks for the help.
Skin
"Trail is life..."
#rideyoureffingbike
- Lloydz VFC
- Lloydz Air Filter
- Lloydz QTTR
SkInM4N is offline
post #9 of 15 (permalink) Old 05-29-2019, 10:24 PM
djh3's Avatar
Contact Joe at cycle terminals. He has helped me many times figuring out what kind of connectors I have.
SkInM4N likes this.
2013 XCT added Jan 2015
djh3 is offline
post #10 of 15 (permalink) Old 05-30-2019, 07:06 AM Thread Starter
SkInM4N's Avatar
Nice! I never knew a site like that existed. I will give them a shout so I can do the correct repair, even though my rigged setup seems to work well
"Trail is life..."
#rideyoureffingbike
- Lloydz VFC
- Lloydz Air Filter
- Lloydz QTTR
SkInM4N is offline
Similar Threads
Thread Thread Starter Forum Replies Last Post
MPG after 02 sensor disconnect maurice Victory Tech and Performance Section 44 04-08-2014 10:05 AM
Map sensor replacement mcotty Victory Tech and Performance Section 8 06-04-2013 10:46 PM
WANTED left hand control harness 07ACE Motorcycle Parts For Sale / Wanted 0 04-09-2010 10:18 PM
