brake noise - Victory Forums - Victory Motorcycle Forum
 8Likes
post #1 of 17 (permalink) Old 05-27-2019, 12:40 AM Thread Starter
psychodiablo's Avatar
Send a message via AIM to psychodiablo
Question brake noise
hand new tires put on and new rear pads an had front pads checked. now when applying front brakes there is a noise that sounds like cicada bugs till i let off. what the fuk
Leesville Louisiana. 2012 cross country, speedo upgrade,forged engine guard,touring sheild, tri oval pipes, Lloyds gen 3 fuel controler, Lloyds highflow airfilter. Lloyds timeing wheel, msd coils,Lloyds 8.2 mm red wires,tank lift/spacers,tank wings,side cover scoops,audio input cord,drivers back rest, 2in pull back bars,polk 5.25 speakers,XC Mag baffles,rockford fosgate pbr400x4 amp,lower wind deflectors,sylvainia ZXE Gold h-11 headlights. rivco hiden hitch. IDMW,FYIYDLMOMB.
psychodiablo is offline
post #2 of 17 (permalink) Old 05-27-2019, 12:44 AM
post #3 of 17 (permalink) Old 05-27-2019, 12:47 AM Thread Starter
might wal-mart have the grease. i might take it back to shop and make them fix it. because it didnt do it before the service.
Motorbikerx and CanuckRob like this.
post #4 of 17 (permalink) Old 05-27-2019, 06:15 AM
depot picker's Avatar
I run the EBC sintered pads. They definitely makes that noise you describe. It is to let the Harley in front know he is going too slow.
Blowndodge and smokier104 like this.
depot picker is offline
post #5 of 17 (permalink) Old 05-27-2019, 01:37 PM
more then likely all the pads need is some scuffing with sandpaper.
If your going to do the work lay a peace of coarse sandpaper on a flat surface. Now take pads and run across the sandpaper a few times. You only need 3 or 4 swipes.
NO walmart doesn't care that grease
post #6 of 17 (permalink) Old 05-27-2019, 11:29 PM
Blowndodge's Avatar
My EBC pads make the same sound. I ignore it.
2013 Victory XCT. Lakewood, CA
Russell Day Long Saddle.
7Jurock 14" tinted flip shield
Unplugged O2 sensors.
Stage one filter.
14" replacement ant.
Drag Specialties highway pegs.
Custom Pin-striping.
Blowndodge is offline
post #7 of 17 (permalink) Old 05-28-2019, 07:34 AM
gamewarden's Avatar
My Lyndalls make the same noise.
2011 custom Tequila Gold with Candy Orange accents, hard lowers and trunk, Ipod in lowers, HID and saddle bag bars, stage 1, heel shifter, front and back chrome fender guards,Garmin GPS, fairing wind deflectors, heated Gerbing hook up, Dain skull brake pedal, rear brake master and reservoir cover, custom cheese wedge cover, clutch cover, Witchdoctor cam covers, Wolo Bad Boy horn, heated grips and seat, Gorilla alarm, Vision rear engine brackett covers, Kruzer Caddy, WD exhaust tips.
gamewarden is offline
post #8 of 17 (permalink) Old 05-28-2019, 08:02 AM
Motorbikerx's Avatar
my Lyndalls either don't make any noise,..that or I cant hear em above my RPW exhaust
Yeah take it back to them.
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is offline
post #9 of 17 (permalink) Old 05-28-2019, 09:50 AM
No such noise from the oem pads or from the Lyndall Gold pads.
Motorbikerx likes this.
All the best,
Mark
www.bikersforchrist.org
"That's a beautiful Victory!"
"Thank you."
"Who makes it?"
"No one."
Chattanooga Mark is offline
post #10 of 17 (permalink) Old 05-29-2019, 05:41 AM
TNXR's Avatar
This has been discussed before and it is the pads. I also put on some EBC pads a year or so ago and mine do the same thing. The consensus from this forum and some buddies who ride HD's and have the same problem is the noise is caused by air escaping between the pad and disc. I bought a set of OEM pads to go back on but going to live with the EBC's for another season.
2011 Cross Roads Sunset Red
TNXR is offline
Similar Threads
Thread Thread Starter Forum Replies Last Post
EBC brake pad noise TNXR Victory Cross Country and Cross Roads 21 06-11-2018 09:40 PM
NEED and WTB stock brake lever or clutch/brake set PFFpro25 Motorcycle Parts For Sale / Wanted 0 10-04-2014 10:39 AM
Front Brake Noise is Irritating jackpot21 Victory Tech and Performance Section 28 06-23-2012 12:23 PM
xc brake noise captainjl Victory Cross Country and Cross Roads 4 06-13-2011 06:44 PM
WTB Front brake line, chrome headlight cover and front brake switch danny23 Motorcycle Parts For Sale / Wanted 0 01-22-2011 01:39 AM
