Removing rear shock. - Victory Forums - Victory Motorcycle Forum
 2Likes
  • 1 Post By Tarzan
  • 1 Post By Richie271
post #1 of 7 (permalink) Old 06-03-2019, 10:14 PM Thread Starter
Default Removing rear shock.
So, I ordered and received the Penske shock and I'm trying to get the old shock out of there. I ran across a video advocating grinding off one side of the lower bracket but I find it difficult to believe that mechanics would have to do that to get the shock out. Having said that, I'm following the instructions in the service manual and I'm finding it quite a challenge to get that damn thing out of there. So, looking for some experience advice.
1) What's the best way to get the current shock out of there? I'd rather keep it intact, but I'll do what I must to get it out of there.
2) Am I going to have to grind anything to get the Penske shock in there? If so, what?
Many thanks, as always!
2013 Suede Nuclear Sunset Cross Country
Vicbaggers Tarzanz handlebars
Thrush modded exhaust
Saddlebag rails
Avon grips and Avon shifter pegs
Kuryakyn Liberator highway pegs with stirrups
and much more
See this post for more details.
Wyckedjester is offline
post #2 of 7 (permalink) Old 06-03-2019, 11:25 PM
BP6666VR's Avatar
Taking the shock out of a cross bike cannot be that difficult ?
When I changed my tire i removed that pin on top of the shock and it was not very difficult ....
@RICZ wrote a nice modification regarding this pin, and if you would read that, then taking out the shock would not be a problem right ? If you can take out your rear wheel then you can take out your shock ... Same thing ...
Andre using TaPaTaLk
Cross Country Tour 2014 [B]
BP6666VR is offline
post #3 of 7 (permalink) Old 06-04-2019, 07:07 AM
Tarzan's Avatar
Pull the pin, and the bottom link bolts. drop the shock down and rotate it rearward. You have to finagle it a little. But Iíve never ground anything and Iíve change a couple of them out. And helped a friend change out his lowering link last week.
SkInM4N likes this.
'14 Ness XC
Tarzan is online now
post #4 of 7 (permalink) Old 06-04-2019, 07:08 AM
WeekendRider's Avatar
It's been a while since I swapped mine out as part of the 21" upgrade kit but I remember it being difficult. As I recall the instructions say to remove the swing arm. What I remember doing was having someone forcibly spread the frame and the swing arm by putting their feet on the swing arm and pulling up somewhere down low by the fender. It gave just enough room to get it out.
2013 XC Suede Nuclear Sunset
21" Conversion incl. ABS Module, Rear Shock and Forks
Lowered...a lot
RCX Slip-ons
Lloydz HPT Cams
Lloydz Air Filter
Lloydz Timing Gear +4
31 Tooth Drive Pulley
Southern Motorworx Tune: 118.08 HP - 114.97 Torque (before 31 tooth drive pulley)
WeekendRider is offline
post #5 of 7 (permalink) Old 06-04-2019, 08:00 AM
It was a tight fit getting the old one out but it did come out. I did have to tussle with it a little. I don't remember grinding that lower piece but I may have. It would take just a few seconds on my grinder (hand or bench).
post #6 of 7 (permalink) Old 06-04-2019, 08:26 AM
Richie271's Avatar
I followed the Witchdoctors video and ground a bit off the lower shock bracket and I have no problem removing or installing the shock. I used an angle grinder and did it in place before removing the first time.
SkInM4N likes this.
Richie271
Long Island, NY
2010 Cross Roads. Midnight Cherry.
Richie271 is offline
post #7 of 7 (permalink) Old 06-05-2019, 11:26 AM Thread Starter
So, I was able to get the shock out by getting the bike as far off the ground as I could thereby letting the swing arm down as far as possible. There still wasn't enough clearance, but I cleared the bracket on the bottom of the shock by hitting the bracket with a screwdriver and hammer. That pushed it through.
Also was able to get the Penske shock in after much wailing and gnashing of teeth. You really have to do things in the right order or you'll have to step back and redo them. The service manual was slightly helpful, but not much overall.
Anyway, thanks to all that replied and if anyone runs across this thread and wants specifics in the future hit me up and I'll share my experiences.
Thanks again and have a good one out there!
Saddlebag rails
and much more
