Leak due to part breakage. - Victory Forums - Victory Motorcycle Forum
 12Likes
post #1 of 14 (permalink) Old 06-06-2019, 12:39 PM Thread Starter
Default Leak due to part breakage.
So, I've got a rubber elbow connector that appears to have gone bad (see attached image). It's split at the bottom so the hose is loose and whatever is going through that hose is leaking out a bit. Anyone know what that hose is for or what it or that elbow connector is called? I looked through the Victory parts list/diagrams and through the service manual and couldn't identify. Any pointers would be appreciated.
Also, what's the best place to order parts like that these days? Thanks!!
2013 Suede Nuclear Sunset Cross Country
Vicbaggers Tarzanz handlebars
Thrush modded exhaust
Saddlebag rails
Avon grips and Avon shifter pegs
Kuryakyn Liberator highway pegs with stirrups
and much more
See this post for more details.
Wyckedjester is offline
post #2 of 14 (permalink) Old 06-06-2019, 12:49 PM
Go to NAPA and ask for a FORD PCV elbow or at auto zone look on there help rack
post #3 of 14 (permalink) Old 06-06-2019, 01:41 PM
It's the engine breather. VJ has the right idea. Take it off and into a parts store to see if you can match up that rubber boot. If you buy it from Polaris; they want you to buy the entire thing and it isn't cheap. Been seeing a lot of this lately.
Motorbikerx likes this.
BBob is online now
post #4 of 14 (permalink) Old 06-06-2019, 06:17 PM
depot picker's Avatar
Mine broke at the top end. I got a piece of flexible hose the fit over the pressed in fitting and it went either inside or outside the hose. Canít remember, but it works.
rojo154 likes this.
depot picker is offline
post #5 of 14 (permalink) Old 06-07-2019, 10:30 PM
roboots21's Avatar
This is what I did for mine when it cracked on me ..
Sent from my Pixel 2 XL using Tapatalk
**2012 Victory Cross Roads** 118HP / 122 LB/FT - Tuned by Lloydz
-- Lloydz Intake/IAV/ATS/VM1-DR -- PCV -- Atom Bombs -- UDP -- Victory Tach/Fairing/Mirrors/Backrest/Luggage/LED/Boards/Heel Shift -- 1" Drop -- Corbin Dual Tour Seat -- Accel Wires -- Mastiff Dipstick -- Rear/Brake/Shift/Highway ISO Pegs/Grips -- Stebel -- HMD Bars -- Barnett -- Ness Primary/Cam Covers -- 21" RC Components 'Gunner' Wheel -- Avons --
2006 Victory Vegas (TRADED)
1982 Honda Magna V45 (SOLD)
roboots21 is offline
post #6 of 14 (permalink) Old 06-18-2019, 07:55 PM Thread Starter
I wound up just ordering the full Victory part. Couldn't find a good match and didn't really wanna screw with it any further...
Saddlebag rails
and much more
post #7 of 14 (permalink) Old 06-20-2019, 03:03 PM
That is zactly how I handled it on my Harlees from day one. VW filters instead of the factory OEM way of scavenging from the engine and blowing it into the air filter... Pleeeeze.
roboots21 likes this.
2012 Cross Country Tour - VroomHilda
Dobeck EJK Gen3 Fuel Tuner with Innova AF meter
Vic K&N knock off Air filter
Lloyds Timing Wheel +4
Relocated Air Shock fill hose
WD SkidPlate reinforced
Hyper running/brake lights
Garmin GPS
Existential Secular Humorist with warrior Buddhist leanings
*Rider/Owner continuous since 1973 - 877,000+ miles USMC R
SemperVee is offline
post #8 of 14 (permalink) Old 06-20-2019, 11:38 PM Thread Starter
What air filter is that?
Saddlebag rails
and much more
post #9 of 14 (permalink) Old 06-21-2019, 08:24 AM
BP6666VR's Avatar
Air filter, coffee filters don't work, smile
Andre using TaPaTaLk
Cross Country Tour 2014 [B]
BP6666VR is offline
post #10 of 14 (permalink) Old 06-21-2019, 08:30 AM
If you blow the picture up you can see what I think says "K&N".
https://amazon.com/s?k=K%26N+engine+...ref=nb_sb_noss
RoteBaron likes this.
BBob is online now
