Low idle - Victory Forums - Victory Motorcycle Forum
 4Likes
post #1 of 11 (permalink) Old 06-30-2019, 07:49 PM Thread Starter
rainman123's Avatar
Default Low idle
I have a 2012 xr and Thursday my idle started running low and had cut the engine off at one point when I was slowing down for a red light on my way to work
Had been running around 850-900 rpm and will drop to 450-500 rpm when stop
Already looked for vacuum leaks and didn't find any
What else can I look for to fix my low idle
2012 crossroad
08 r3t traded for xr
06 rocket classic totaled
98 t-bird traded for rocket
73 sportster sold
72 honda 350 long gone
06 rocket3 classic
rainman123 is offline
post #2 of 11 (permalink) Old 06-30-2019, 07:54 PM
depot picker's Avatar
Mine will do that if I slow down quickly and Iím low on fuel.
SkInM4N likes this.
depot picker is offline
post #3 of 11 (permalink) Old 06-30-2019, 07:58 PM Thread Starter
rainman123's Avatar
My tank was full and slowing down easy it's dark when I go to work and it started all at once with no warning
2012 crossroad
73 sportster sold
06 rocket3 classic
post #4 of 11 (permalink) Old 06-30-2019, 08:45 PM
I had this same issue on a 3rd Gen 4Runner. I fixed it by simply changing the plugs/wires and cleaning the throttle body. A dragging clutch might add to the issue if it does it in gear with the clutch pulled.
Just throwing some ideas/thoughts out there for you to ponder since you already addressed one of the most common causes; a vacuum leak. I wouldn't think a failing fuel pump would cause this but who knows.
post #5 of 11 (permalink) Old 07-02-2019, 07:48 PM Thread Starter
rainman123's Avatar
I believe I got it fix I spray some carb cleaner on the right side after I toke the cheese wedge off and been to running right since then
2012 crossroad
73 sportster sold
06 rocket3 classic
post #6 of 11 (permalink) Old 07-03-2019, 01:51 PM
never rule out battery age and bolts
post #7 of 11 (permalink) Old 07-03-2019, 10:45 PM
rojo154's Avatar
Sure sounds like a vacuum leak to me. You got 3 vacuum lines right there on the iac.
You didn't say what or exactly where you sprayed. Don't see how that would fix anything. Did the rpms change when you sprayed the carb cleaner?
2011 Kingpin
custom paint
Ness fly bars
xbow exhaust
S&S air intake
Dobeck fuel controller
chrome floorboards
cruise control
2004 Kingpin
Victory performance exhaust
customized air box / K+N filter
LLoydz fuel controller
custom oil lines
custom led lighting
custom led third brake lights
Sold ..( my baby, still have some sellers remorse)
2011 XC
rpw exhaust
wiseco fuel controller
Sold
rojo154 is offline
post #8 of 11 (permalink) Old 07-04-2019, 07:20 PM Thread Starter
rainman123's Avatar
No the rpm did not change when I sprayed I sprayed all under the gas tank on the right side
No rpm changes while spraying that's why I decided no vaccum leak it's been running like it should but I am getting ready to order new plug wires for it having almost 115000 miles on it
2012 crossroad
73 sportster sold
06 rocket3 classic
post #9 of 11 (permalink) Old 07-04-2019, 08:34 PM
It might be a shot in the dark but with that many miles I have to wonder if some of that carb cleaner made it into the throttle body somehow and and cleaned just enough to make it run right for a while.
The earlier pre-closed loop Vic's required a regular throttle body cleaning which meant pulling the tank of course. With that amount of miles; I'd say yours is due for a nice cleaning too. Probably be good for another 100k as long as everything else holds up. It would be good time to really look at all the rubber parts under the tank with a bright flashlight though.
rainman123 likes this.
post #10 of 11 (permalink) Old 07-04-2019, 09:45 PM
rojo154's Avatar
Glad to hear the bike is running better. Still, what caused such a huge drop in rpm? I take it the bike ran fine while driving. Your symptoms seem to occur while throttle is closed and have vacuum. I still have to think vacuum leak. There are 2 lines which run between the cylinders from the iac. They go around each cylinder to the front side and back side . The rubber connectors are know for splitting. These are more accessible from the left side of the bike. With that mileage/ age I would think they would be suspect.
2011 Kingpin
custom paint
Ness fly bars
xbow exhaust
S&S air intake
chrome floorboards
cruise control
2004 Kingpin
custom oil lines
custom led lighting
2011 XC
rpw exhaust
Sold
rojo154 is offline
