Left Radio Control problems - Victory Forums - Victory Motorcycle Forum
 6Likes
post #1 of 12 (permalink) Old 07-02-2019, 09:55 PM Thread Starter
djh3's Avatar
Default Left Radio Control problems
A couple days back I was riding and I tried to change playlists on the IPod. Control will not even bring up the play list. Mashed it several different ways and finally go it to change. But it does not work like it should. Anybody had issues like this? Any ideas of a fix short of financing the comeback of Victory? I tried to look for one online and I think they want over $150 for it if I had the right part #. The rest of the buttons seem to work OK.
2013 XCT added Jan 2015
djh3 is offline
post #2 of 12 (permalink) Old 07-03-2019, 07:25 AM
SkInM4N's Avatar
Could be an issue with corrosion or just a little dirt. Maybe a hit with electrical contact cleaner will help. Worth a shot. WD-40 Specialist makes a good one.
Hope this helps. Good luck.
Skin
RoteBaron likes this.
"Trail is life..."
#rideyoureffingbike
2016 Victory CCT "Miss Pearl"
- Lloydz VFC
- Lloydz Air Filter
- Lloydz QTTR
- Taylor Thundervolt wires
- Victory Tri-Ovals (no baffles)
SkInM4N is offline
post #3 of 12 (permalink) Old 07-03-2019, 11:12 AM Thread Starter
djh3's Avatar
Well it is all sealed. Its a "depression" pad sort of deal. No switch visable everything sealed.
djh3 is offline
post #4 of 12 (permalink) Old 07-03-2019, 11:26 AM
SkInM4N's Avatar
I must be thinking of something different then. Do you have a picture of what you are referring to since I am drawing a blank.
Skin
"Trail is life..."
#rideyoureffingbike
- Lloydz VFC
- Lloydz Air Filter
- Lloydz QTTR
SkInM4N is offline
post #5 of 12 (permalink) Old 07-03-2019, 01:36 PM
roboots21's Avatar
I had something similar happen and it turned out to be the iPod. I hooked up a different iPod and worked perfectly. Once I reset my iPod, everything was back to normal. So, may want to try a reset of your iPod and see if that helps or try someone else's iPod if you haven't already.
visionjohnny, 541RF and SkInM4N like this.
**2012 Victory Cross Roads** 118HP / 122 LB/FT - Tuned by Lloydz
-- Lloydz Intake/IAV/ATS/VM1-DR -- PCV -- Atom Bombs -- UDP -- Victory Tach/Fairing/Mirrors/Backrest/Luggage/LED/Boards/Heel Shift -- 1" Drop -- Corbin Dual Tour Seat -- Accel Wires -- Mastiff Dipstick -- Rear/Brake/Shift/Highway ISO Pegs/Grips -- Stebel -- HMD Bars -- Barnett -- Ness Primary/Cam Covers -- 21" RC Components 'Gunner' Wheel -- Avons --
2006 Victory Vegas (TRADED)
1982 Honda Magna V45 (SOLD)
roboots21 is offline
post #6 of 12 (permalink) Old 07-03-2019, 09:00 PM
You hold couple buttons to reset the iPod. I've been doing that a few times with mine lately.
post #7 of 12 (permalink) Old 07-05-2019, 10:13 PM Thread Starter
djh3's Avatar
Well I'll try turning it off and back on tomorrow maybe. But I dont think that is going to fix it. But heck it dont cost nuttin.
djh3 is offline
post #8 of 12 (permalink) Old 07-08-2019, 10:55 PM Thread Starter
djh3's Avatar
Okey Dokey Charged up Ipod, it was pretty much DOA when I went out to reset. So for now it seems to acting normally. Changes and resets playlist etc. So I dunno maybe its all good and for some reason a low battery or something else created a snag.
djh3 is offline
post #9 of 12 (permalink) Old 07-09-2019, 09:50 AM
SkInM4N's Avatar
Hopefully that's all it was. Sometimes I will have things happen which I can't really get to repeat so hopefully this bug won't creep back up again. Call that a win.
Skin
"Trail is life..."
#rideyoureffingbike
- Lloydz VFC
- Lloydz Air Filter
- Lloydz QTTR
SkInM4N is offline
post #10 of 12 (permalink) Old 07-09-2019, 04:14 PM
RoteBaron's Avatar
Had something similar to that where my frickin' iPOD wouldn't come up at all. Just got "AUX". After it charged up it was fine. Those Apple (AKA "Big Brother") products can be finicky. I was about ready to take the bike apart when I realized it (the IPOD) might be the culprit. I've learned a couple of times the hard way to "KEEP IT SIMPLE" . Had a problem with my power point in the Vision glove box. Was fixin' to tear it the fairing of and chase that line down. Something told me to look in power point itself. (DamnedifIknow what). Turned out to be a piece of plastic had fallen into the socket......KISS brother. Start with the simplest stuff first ;-) LMYR
Long may you ride!
RB
2013 Vision Sunset Red
Lloydz Timing wheel @ 3deg
Victory High Flow Air Filter
2017 Highball - Suede Nuclear Sunset Orange
RoteBaron is offline
