Help with Starting Issue - Victory Forums - Victory Motorcycle Forum
 4Likes
  • 2 Post By RoteBaron
  • 2 Post By ColoradoCCT
post #1 of 9 (permalink) Old 07-07-2019, 01:17 PM Thread Starter
ColoradoCCT's Avatar
Default Help with Starting Issue
My CCT sat idle for about two years (story for another time).
There was corrosion in the gas tank and I could tell the fuel pump went bad as it wasn't priming. I cleaned out the corrosion in the tank, replaced the fuel pump, fuel regulator, and spark plugs. There was no evidence of corrosion in the fuel lines whatsoever. I can hear the fuel pump priming, spark plugs are getting spark, turns over perfectly fine.
It still doesn't want to start... What should I check next? I imagine the fuel injectors are next but they look difficult to access. Is an engine removal necessary for that?
Thank you!
ColoradoCCT is offline
post #2 of 9 (permalink) Old 07-07-2019, 03:00 PM
Are you able to verify you have fuel pressure and spark?
You might be right about the injectors. They should be able to be cleaned. There's an entire section on the fuel system and injectors. They look the same as the ones on cars for the most part.
Are they difficult to get at? Yes; but doable.
post #3 of 9 (permalink) Old 07-07-2019, 07:58 PM
RoteBaron's Avatar
Try starting. Pull plug(s) see if they are wet. If wet (aka fuel on them) test for spark. Finally, we're assuming you have compression. The only other thing would be air. Soooo before you replace anything, rip out anything, see if the fuel is getting to the plug. Make sure the plug is working. If you have no fire or fuel to the fire it ain't gonna run. Not sure I'd do it but on less "advanced" systems we use starter fluid. In that vein you could (not sure how possible this is on our bikes) spray a small (SMALL) amount of fuel (prime it) directly into the air box to see if it fires. IF it starts on the prime, it stands to reason fuel is not getting into the chamber. Before jerking out the injectors make sure the fuel is getting to them. Hope this helps. Just my 2cents. LMYR
Speedblue and SkInM4N like this.
Long may you ride!
RB
2013 Vision Sunset Red
Lloydz Timing wheel @ 3deg (Soon to go)
Victory High Flow Air Filter
Soon to tune with Maximus
2017 Highball - Suede Nuclear Sunset Orange
Xbow exhaust, High flow air filter, Lame stage 1 update (MEH)
RoteBaron is offline
post #4 of 9 (permalink) Old 07-08-2019, 08:06 AM
Richie271's Avatar
Any chance a mouse made a home in the air delivery system?
It happens.
Richie271
Long Island, NY
2010 Cross Roads. Midnight Cherry.
Richie271 is offline
post #5 of 9 (permalink) Old 07-08-2019, 09:15 AM
It happens.
Good point. We don't know what we don't know.
post #6 of 9 (permalink) Old 07-08-2019, 11:11 PM Thread Starter
UPDATE
It started up right away this morning. I might have flooded it when trying to get the lines to prime after draining.
It sounds bad, doesn't want to idle, and was shooting out flecks of corrosion. Sounds fairly normal at high RPM. Could just be from the pipes as it wasn't ever run with the corrosion in the tank.
I think I'll try a can of Seafoam and watch a witchdoctors video on fuel injectors.
Speedblue and PaiN like this.
post #7 of 9 (permalink) Old 07-09-2019, 02:59 PM
rojo154's Avatar
Originally Posted by ColoradoCCT View Post
UPDATE
The mouse theory is sounding more likely. Those flecks of corrosion just may be mouse nest getting either sucked into the throttle bodies, or threw the iac system. If that is plugged the bike won't run right at idle or low throttle opening but better when throttle is opened harder. This ain't the first time we have heard of this. .....and again, check for vacuum leaks.
2011 Kingpin
custom paint
Ness fly bars
xbow exhaust
S&S air intake
Dobeck fuel controller
chrome floorboards
cruise control
2004 Kingpin
Victory performance exhaust
customized air box / K+N filter
LLoydz fuel controller
custom oil lines
custom led lighting
custom led third brake lights
Sold ..( my baby, still have some sellers remorse)
2011 XC
rpw exhaust
wiseco fuel controller
Sold
rojo154 is offline
post #8 of 9 (permalink) Old 07-09-2019, 03:45 PM
@ColoradoCCT I was thinking a big dose of Seafoam might do a world of good....provided your air intake is clear.
post #9 of 9 (permalink) Old 07-10-2019, 10:14 AM Thread Starter
I will check this today!
