Why are the two front bleed bolts different head sizes? - Victory Forums - Victory Motorcycle Forum
 6Likes
post #1 of 13 (permalink) Old 07-10-2019, 02:58 PM Thread Starter
Default Why are the two front bleed bolts different head sizes?
I have speed bleeders coming. Mainly because of the rear having caliper on wrong side for solo vacuum bleeding.
I ordered what is posted in old threads but I don't see any mention of the bolts being different size heads. Just different lengths. Which makes me a little concerned about having wrong size bleeder coming.
post #2 of 13 (permalink) Old 07-10-2019, 07:47 PM
Dunno why the difference, but the left front is longer that the other two. I THINK the item numbers are (front left) SB125LL and the other two are SB125L.
post #3 of 13 (permalink) Old 07-10-2019, 07:52 PM
cooper's Avatar
Default Bleeders
I also had to bleed my front brakes and noticed they were two different sizes. Did it the old-school way stuck a hose on the end of the bleeder and pump the brakes. But the hose was a different size for the left compared to the right.
2013 Victory Cross Country
2015 Arctic Cat XF8000
cooper is online now
post #4 of 13 (permalink) Old 07-10-2019, 08:10 PM
I keep telling people that the BEST WAY to get the correct Seed Bleeders is to PHONE in the order. What's so intimidating about picking up your phone and actually talk to someone who knows more than you? Sheesh! I'm on another forum where people have ordered the wrong Speed Bleeders. It's worth getting the right ones as they make getting good, firm levers and pedals stupid easy.
post #5 of 13 (permalink) Old 07-10-2019, 08:53 PM
depot picker's Avatar
Ewe. Rather not thanks.
RICZ and CanuckRob like this.
depot picker is offline
post #6 of 13 (permalink) Old 07-10-2019, 09:31 PM Thread Starter
SB8125L.
My Honda would use same if I switched. Same caliper manufacturer.
They are on, bleeding is done and that nasty fluid is gone. I've seen plenty of posts about the front brake being difficult to get bled right. Ran what I consider a ton of fluid through it to be safe.
RICZ likes this.
post #7 of 13 (permalink) Old Yesterday, 07:28 AM
Richie271's Avatar
Did you follow the shop manual?
Richie271
Long Island, NY
2010 Cross Roads. Midnight Cherry.
Richie271 is offline
post #8 of 13 (permalink) Old Yesterday, 07:44 AM Thread Starter
Yep. Will test ride tonight and see if it better.
post #9 of 13 (permalink) Old Yesterday, 08:12 AM
wspollack's Avatar
Default Pic of 2015 Order
Please see my 2015 post https://www.victoryforums.com/36-vic...ml#post1710081 (in the thread https://www.victoryforums.com/36-vic...firmation.html ). I show a scan of my actual order back then, which parts then went on my actual XCT (which @Vinish now owns):
One SB8125LL, and two SB8125L
Why Vic/Polaris chose to use different sizes -- stock -- for the front two discs is unknown to me (and I don't recall ever reading an explanation of that choice).
Cheers,
Bill P.
wspollack is offline
post #10 of 13 (permalink) Old Yesterday, 08:46 AM
Motorbikerx's Avatar
what? actually talk on a teleohone???...nonono no one does that any more! TXT or EMAIL
You might hear my voice!, thats way too scary!...and what if you ask me something?...I'LL have to think what to say oh my god its all too hard!!! just txt me, thats easier
RICZ and mh1 like this.
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is offline
