XC tank spacers/lift and filling tank - Victory Forums - Victory Motorcycle Forum
 3Likes
  • 3 Post By vindex1963
post #1 of 6 (permalink) Old 07-22-2019, 10:41 PM Thread Starter
djh3's Avatar
Default XC tank spacers/lift and filling tank
I dont know why but I have been thinking about a set of these. But the listing I just saw showed a level sitting across the filler cap. And with the angle it apears you might draw more fuel out of the tank, but you wont be able to get as much in it as no fuel will be able to get to the most forward point. So has your range changed?
2013 XCT added Jan 2015
djh3 is offline
post #2 of 6 (permalink) Old 07-23-2019, 08:08 AM
I would think if the tank is tilted up slightly in the front, you might be able to squeeze more fuel in there. But I can't see it being a major difference as the tank only lifts what, .5 inch? .75 inch? Can't say, I don't have them but I personally have no desire for them.
post #3 of 6 (permalink) Old 07-23-2019, 08:12 AM
vindex1963's Avatar
I have them and I don't think you can get more fuel in.
Performance, save your money.
RICZ, visionjohnny and broggyr like this.
1/4 turn throttle ring
Tank riser
VM-1 DR cams
Timing wheel +4
Lloydz high-flow air cleaner
Bassani baffled OEM mufflers
PC-V 118hp 116tq
vindex1963 is online now
post #4 of 6 (permalink) Old 07-23-2019, 12:16 PM
Dusty Boots's Avatar
NO discernible difference that I can tell.
The tank is a PITA/time consuming to fill completely for long rides anyways
Dusty
2013 Victory XCT - SW Ontario
Stage 1 Victory Tri Oval kit, with EFI retune
Lloydz Timing Wheel (+3)
Quarter turn throttle ring
It's never too early to plan and never too late to go!
Dusty Boots is offline
post #5 of 6 (permalink) Old 07-23-2019, 07:56 PM
I have the Bad Ace Billet 1" tank risers. The only real world difference I ever noticed is that now when the low fuel light comes on I have less than a gallon. Prior to the tank risers it would come on at over a gallon.
I take the time to top off my tank to within an inch of the opening when I know I'm getting right back on the road for at least 40 miles or so. But topping off the tank sometimes depends on the release of the pump handle. Some of then are like a switch, all or nothing while others can be feathered to easily top off the tank.
All the best,
Mark
www.bikersforchrist.org
"That's a beautiful Victory!"
"Thank you."
"Who makes it?"
"No one."
Chattanooga Mark is offline
post #6 of 6 (permalink) Old 07-23-2019, 08:45 PM Thread Starter
djh3's Avatar
Thanks Mark, that was kind of what I was looking for and thought. With the tank "tipped" it would kind of throw the level gauge, and associated things a bit off.
Those of us that had Ventures had fueling problems topping off. A lot of us punched a hole kind of in the vertical part of that flange where we have the oval cut out. It would act like a vent so as your filling and the air has to get out, it has a place to go instead of back up and kick the pump off.
djh3 is offline
