2014 XCT ABS issue - Victory Forums - Victory Motorcycle Forum
post #1 of 9 (permalink) Old 08-14-2019, 03:31 AM Thread Starter
Location: Cairns area. Far North Queensland, Australia.
Default 2014 XCT ABS issue
The ABS light has illuminated on the dash of my bike. It had happened a couple of years ago and I replaced the front wheel speed sensor which solved the issue.
I thought it was probably a similar issue so purchased a new sensor and fitted it to the front on Monday afternoon. Unfortunately it didn't fix the problem, so I left the new one fitted to the front and kept the one I'd removed, figuring the rear sensor must have been bad.
This afternoon I removed the rear sensor and replaced it with the one I'd removed from the front on Monday. Buttoned everything up and test rode but still no dice - that damn light stayed on.
I ensured that the same spacer washers went back in as they had been and the sensor to ABS ring gap at both ends is 1mm.
Any ideas?
Russ.
2014 XCT in Bronze Mist
2000 H-D Road King
2003 Suzuki SV1000
2003 Aprilia SL1000R
1977 Honda CB750K7
Plus a few others in the shed
ozpacman is offline
post #2 of 9 (permalink) Old 08-14-2019, 05:10 AM
Bugs, dirt, etc on the sensor or the ring.
Have you done any bike work recently?
post #3 of 9 (permalink) Old 08-14-2019, 06:29 AM Thread Starter
Thanks IV.
I've cleaned the sensors and rings to no avail. The light came on around the same time I fitted new front and rear tyres however I can't think of anything I did differently that may have effected the ABS.
What I have noticed is that my front brake lever is now quite spongy on the initial application and then firms up if you squeeze it a second time - almost like air in the system and in need of bleeding.
Does anyone know if this is something that occurs due to the ABS not functioning correctly?
2000 H-D Road King
2003 Suzuki SV1000
1977 Honda CB750K7
ozpacman is offline
post #4 of 9 (permalink) Old 08-14-2019, 06:57 AM
I believe the abs is a passive system. It doesn't interfere with brake operation unless it is activated.
If your lever feels off I'd bleed the system until it feels right. Just my opinion. I like to stop.
post #5 of 9 (permalink) Old 08-14-2019, 08:59 AM
Motorbikerx's Avatar
black electrical tape over the light...about to 'fix' the 'check engine' light on my Subaru
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is offline
post #6 of 9 (permalink) Old 08-14-2019, 04:13 PM
WeekendRider's Avatar
Maybe these will help...
2013 XC Suede Nuclear Sunset
21" Conversion incl. ABS Module, Rear Shock and Forks
Lowered...a lot
RCX Slip-ons
Lloydz HPT Cams
Lloydz Air Filter
Lloydz Timing Gear +4
31 Tooth Drive Pulley
Southern Motorworx Tune: 118.08 HP - 114.97 Torque (before 31 tooth drive pulley)
WeekendRider is offline
post #7 of 9 (permalink) Old 08-15-2019, 01:36 AM Thread Starter
Thanks for your responses guys, I'll have a bit more of a look at things this weekend and see what I can come up with.
I might even end up going with your 'Bush mechanics' solution MBX!
2000 H-D Road King
2003 Suzuki SV1000
1977 Honda CB750K7
ozpacman is offline
post #8 of 9 (permalink) Old 08-15-2019, 04:54 AM
There are old posts where people had to fool with the shims after changing tires. It seems the sensors are happier with a slightly larger gap for some people. Worth a try.
The problem you have is not knowing if it's front or rear that is upsetting the bike. You'd need dealer tool to get details.
post #9 of 9 (permalink) Old 08-15-2019, 08:21 AM
ObiSteve's Avatar
And make sure the wiring loom to both sensors looks OK. I had the light come on after very rough roads bounced the loom down near the caliper into contact with the rear wheel, which wore through one wire.
2013 Hard Ball
Stage 1 mufflers
K&N air filter
Rubber air dam removed
Reflash
Whole lot of extra cable ties, shrinkwrap and tape on loom
Hard chrome spherical joints in back
Hammer front guard
Wide Glide fork boots
ObiSteve is offline
