Oil Flush - Does anybody do this or is it just me? - Page 2 - Victory Forums - Victory Motorcycle Forum
 16Likes
post #11 of 22 (permalink) Old 09-05-2019, 12:58 PM
BP6666VR's Avatar
Originally Posted by ObiSteve View Post
With my 1990 Sportster with about 400,000 kms on it, every oil and filter change I disconnect the oil return line from the pump, quarter fill the oil tank, and run it until the returning oil is clean, then connect the return line and fill the oil tank fully.
I never had a HD but if i read it right i would like to ask
Instead of "run it" maybe "crank it" untill you have clean oil ... There is no difference but i ensure you it is safer ?
Andre using TaPaTaLk
BBob likes this.
Cross Country Tour 2014 [B]
BP6666VR is online now
post #12 of 22 (permalink) Old 09-05-2019, 01:21 PM
Or just fill the external oil tank, run it till you get clean oil out of the return line, then top off the tank. That's the way I'd do it.
I change the trans fluid in my cars like that except I use an electric pump to pump the clean fluid in while the transmission pumps the old dirty fluid out. When I see clean fluid (usually around the 3 gallon mark) I stop everything and top off the trans fluid.
It's not a fluid flush but rather a full trans fluid exchange. Otherwise you might only drain and fill .5 to 1 gallon depending on make and model. Maybe less.
BP6666VR likes this.
BBob is online now
post #13 of 22 (permalink) Old 09-06-2019, 05:27 AM
TNXR's Avatar
I've never done an "oil flush" and probably never will. Just change the oil at the intervals the manufacturer suggests with the type of oil they suggest. Anything else is just something that makes you feel better but probably not necessary.
2011 Cross Roads Sunset Red
TNXR is offline
post #14 of 22 (permalink) Old 09-06-2019, 09:26 AM
half_crazy's Avatar
Took the engine apart at 94,000 miles. The engine was clean as a pin inside. No deposits or sludge in there at all. Looked new.
BBob and 2011XCRider like this.
2006 Victory Kingpin
half_crazy is offline
post #15 of 22 (permalink) Old 09-06-2019, 10:20 AM
Oil flushing was a thing back in the day of non detergent oil, like the '50s and '60s. Neighbor used to use kerosene to flush his engines when he bought a used car. Haven't heard much about it since the early '70s though. Showing my age here.
Pietperson is offline
post #16 of 22 (permalink) Old 09-07-2019, 05:43 AM
2011XCRider's Avatar
When bought the 2011 XC with 21,600 Miles on it found out that the 20K Service had been done 10 months+ ago .. Changed the Oil ( Victory ) and Rode it Hard until 22,500 and Changed it again plan on doing again at 25,000 then will go back to every 5,000 Miles or 1 Year whichever comes first .. Even if don't make 5,000 Miles within a Year which is unlikely I still Rid eat least once a week main reason changed as soon as I got it is knew it had sat a lot in the past 10 months ..
2011 XC , Love Finding New Roads..
2011XCRider is offline
post #17 of 22 (permalink) Old 09-11-2019, 11:12 PM
SportyDoug's Avatar
Default Oil Flush
I have changed oil early, and then early again, on bikes I have bought that came to me with old oil in them. It seems a prudent action. To me, if no damage has been done, the routine should prevent damage.
I would not flush with Liqui-Moly, although they claim to offer a Motorbike flush that is suitable for motorcycles with wet clutches - when used as directed. To me, the reward does not justify the risk. YMMV.
Like fishing, the best time to go riding is...when you can.
SportyDoug is offline
post #18 of 22 (permalink) Old 09-13-2019, 12:00 AM
rojo154's Avatar
Fill with kerosene, run for 2 minutes and drain.
just kidding. It's way too late and I should be in bed.
I do have to ask why would you install a new filter to filter out any contaminant? I'm sure the old filter is still functioning fine. Its not like it is allowing unfiltered oil threw. All you are doing is starting the new filter off with the contaminants you feel are in the motor.
SportyDoug likes this.
2011 Kingpin
custom paint
Ness fly bars
xbow exhaust
S&S air intake
Dobeck fuel controller
chrome floorboards
cruise control
2004 Kingpin
Victory performance exhaust
customized air box / K+N filter
LLoydz fuel controller
custom oil lines
custom led lighting
custom led third brake lights
Sold ..( my baby, still have some sellers remorse)
2011 XC
rpw exhaust
wiseco fuel controller
Sold
rojo154 is offline
post #19 of 22 (permalink) Old 09-13-2019, 09:47 AM
I think that is an old wives tale like not swimmng for an hour after you eat. From the days of knurling piston skirts and knurling valve guides.
post #20 of 22 (permalink) Old 09-13-2019, 04:31 PM
vindex1963's Avatar
Who oil flushes their lawn mowers is the bigger question.
1/4 turn throttle ring
Tank riser
VM-1 DR cams
Timing wheel +4
Lloydz high-flow air cleaner
Bassani baffled OEM mufflers
PC-V 118hp 116tq
vindex1963 is offline
