Oil Flush - Does anybody do this or is it just me? - Victory Forums - Victory Motorcycle Forum
 16Likes
post #1 of 22 (permalink) Old 09-04-2019, 12:17 PM Thread Starter
Jakvis's Avatar
Default Oil Flush - Does anybody do this or is it just me?
This is not a Oil type Post
As I've mentioned in previous posts I bought a 2014 Cross Country last December.
I did an oil change with-in a month of owning it and I did 4000 miles (now at 26K) and decided it was time to change it again but this time, because I'm not the original owner and who knows what was done before I owned the bike, I decided to do what I call an oil flush.
I replaced the filter and oil with Rotella T5 rode it for about 100 miles and then drained the oil and put in new Rotella T5. I was amazed at how dark the oil got with just the 100 miles on it. It looks like the oil worked well at cleaning up the engine.
I've done this on some older cars I've owned with similar results but usually at 50K miles.
Again this is not an oil post to say what oil is better than another oil (use what you are comfortable using) I was just wondering if anyone else does this. It basically cost me an extra $19 dollars to do this so it certainly isn't expensive to do.
What's your opinion?
Current Stable: 2014 XC, Honda PCX 150, 125 SYM Havana.
Born in the deepest jungles of India, I was raised by a friendly bear, until I was kidnapped by a pack of unruly baboons who taught me the finer points of swing jazz, all the while being stalked by an incompetent python and an evil but mis-understood tiger... Ummm, wait a minute, that's the Jungle book, no I was raised just outside of St. Louis, But...in the deepest jungles of a middle class neighborhood .
Jakvis is online now
post #2 of 22 (permalink) Old 09-04-2019, 12:52 PM
I bet a full synthetic would have cleaned it even better.
You certainly can't hurt it by doing this and it probably helped. Technically the detergents in the oil is supposed to suspend the junk but anyone who has taken an engine apart can tell if it was run for any length of time with dirty black oil that was technically within the mileage change interval. An oil test by an outside company could tell more about if the oil was still good or not.
I've noticed if you change your oil before it gets too black; it will stay cleaner longer with the new oil. Do that every time and common sense says the oil and engine is happier. Again; oil tests may not confirm this though but an engine rebuilder can.
There are oil flush products one can use just before changing the oil to help this process and products that will add certain base metals that will help with the longevity of the engine (like 'Restore').
https://amazon.com/s?k=oil+flush&cri...nb_sb_ss_i_1_9
BBob is online now
post #3 of 22 (permalink) Old 09-04-2019, 04:12 PM Thread Starter
Jakvis's Avatar
With wet clutches I'm a little afraid to add something like Restore. I thought about adding an ounce of Seafoam to the oil to help with the cleaning but just did the T5 by itself.
I was running T6 before but I wanted the 15W/40 of the T5 and so far I can't find it in the T6.
Again though... this is not an Oil Type Post... It's just about flushing the engine out of older deposits and possible some benefits of cleaning the clutch plates.
post #4 of 22 (permalink) Old 09-04-2019, 06:25 PM
The Liqui-Moly engine flush is one the best selling engine flushes. To use you simply pour into the engine, start it, and let idle it for 15 minutes then drain the oil. Probably would not get any into the clutch plates.
Just a thought.
BBob is online now
post #5 of 22 (permalink) Old 09-04-2019, 07:42 PM
BP6666VR's Avatar
I do not like oil-flush, for me a real oil flush is fill with the oil your running, ride 1 hour and renew that oil ....
Oil gets black because your oilcooler is full with old oil, and all your oilchannels inside the block are full with oil, not because you used oilflush
Hope this helps
Andre using TaPaTaLk
broggyr, olddad64 and yago20 like this.
Cross Country Tour 2014 [B]
BP6666VR is offline
post #6 of 22 (permalink) Old 09-04-2019, 08:25 PM
Originally Posted by BP6666VR View Post
<snip>Oil gets black because your oilcooler is full with old oil, and all your oilchannels inside the block are full with oil, not because you used oilflush <snip>
I agree with you.
BP6666VR likes this.
G'day,
Vinish
Our patriotic stable:
Red 2012 XCT (my bike for NC)
Vinish is online now
post #7 of 22 (permalink) Old 09-04-2019, 09:36 PM
A person can simply change their oil sooner. They could even do 1000 mile back to back oil changes.
vindex1963 likes this.
BBob is online now
post #8 of 22 (permalink) Old 09-04-2019, 09:56 PM
vindex1963's Avatar
How has all my vehicles survived all these miles without dumping money and resources down the drain??
Some obsessions are just plain old silly in my opinion. Of course to each their own but really....
Tarzan and depot picker like this.
1/4 turn throttle ring
Tank riser
VM-1 DR cams
Timing wheel +4
Lloydz high-flow air cleaner
Bassani baffled OEM mufflers
PC-V 118hp 116tq
vindex1963 is online now
post #9 of 22 (permalink) Old 09-04-2019, 11:44 PM
ObiSteve's Avatar
With my 1990 Sportster with about 400,000 kms on it, every oil and filter change I disconnect the oil return line from the pump, quarter fill the oil tank, and run it until the returning oil is clean, then connect the return line and fill the oil tank fully.
BBob likes this.
2013 Hard Ball
Stage 1 mufflers
K&N air filter
Rubber air dam removed
Reflash
Whole lot of extra cable ties, shrinkwrap and tape on loom
Hard chrome spherical joints in back
Hammer front guard
Wide Glide fork boots
ObiSteve is offline
post #10 of 22 (permalink) Old 09-05-2019, 07:57 AM
vindex1963's Avatar
Converted that's 248,548 miles, now that's beyond impressive!!!
My old Shovel with 167,000 miles got regular oil changes, drain..fill..go.
Tank riser
VM-1 DR cams
Timing wheel +4
PC-V 118hp 116tq
