Speedometer in Auto turn signal cancel stopped working - Victory Forums - Victory Motorcycle Forum
 2Likes
  • 1 Post By BBob
  • 1 Post By TOWNSENDRO
post #1 of 8 (permalink) Old 09-19-2019, 12:15 PM Thread Starter
Default Speedometer in Auto turn signal cancel stopped working
I clean the turn signal connector, and I ran the speed sensor and cruise control checks. Got no signal from the speed sensor check, and fails on throttle and and speed sensor from the cruise control check. I also cleaned the speed sensor connector. I'm prepared to change the speed sensor, but is there anything else I should check? Help please!!!
TOWNSENDRO is offline
post #2 of 8 (permalink) Old 09-19-2019, 03:03 PM
It makes it so much easier when folks just put what they ride in their signature... Year and Model will do.
TNXR likes this.
post #3 of 8 (permalink) Old 09-19-2019, 07:11 PM
Being in the cross bike forum section one would bet it's a cross bike.
Pic in intro thread is a cross country.
post #4 of 8 (permalink) Old 09-19-2019, 08:07 PM
post #5 of 8 (permalink) Old 09-19-2019, 08:12 PM
Turn signal auto cancel uses speed sensor. If you're below some slow speed it will blink forever. If you're moving fast enough it cuts off.
If your speedometer is also broken as you say then I'd go for replacing the speed sensor. IF that doesn't cure it you have a spare part for future backup use.
post #6 of 8 (permalink) Old 09-19-2019, 09:23 PM Thread Starter
Sorry it's a 2011 Cross country. Thanks I'll swap the sensor.
post #7 of 8 (permalink) Old 09-24-2019, 08:05 AM Thread Starter
I swapped the speed sensor now everything works. Thanks for the advice!
post #8 of 8 (permalink) Old 09-24-2019, 08:15 AM
Glad you found the issue and were able to get it fixed.
