Follow up to my "Switched Power" Thread - Victory Forums - Victory Motorcycle Forum
post #1 of 14 (permalink) Old 05-29-2013, 12:45 PM Thread Starter
SilvrT's Avatar
Default Follow up to my "Switched Power" Thread
The reason I was looking for a source for "switched power" was so I could wire in a fuse block that would serve various auxiliary devices such as extra driving lights, GPS, XM radio, etc. I also needed to install a FIAMM air horn so I could scare the crap outta idiot cagers.
Well, I got the project done and will post some pics later but for now, here is the wiring schematic which shows the source for the switched power. (pull the ignition switch and tap into the brown wired coming off it).
Hoping this will serve to assist others.
NOTE: It says both relays are grounded by post #25... should be 85.
You can swap connections with post #85 & #86 as that makes no difference.
SilvrT is offline
post #2 of 14 (permalink) Old 05-30-2013, 02:42 AM
Just keep an eye on your battery meter when loading up the system. They aren't rated as high as some bikes like the Goldwing.
BBob is online now
post #3 of 14 (permalink) Old 05-30-2013, 04:53 AM
BThomas's Avatar
This is great stuff... Thanks'
Sent from Motorcycle.com App
2012 Cross Country--trunk at times, stereo/amp upgrade, Madstad Windshield bracket, old-man style heated seat/grips, RPW Exhaust/Lloydz ATS and filter, PCV/AT, Cycleops Cheese, side covers and primary insert, soft lowers, a bit of chrome...
BThomas is offline
post #4 of 14 (permalink) Old 05-14-2015, 05:01 PM
MrXC2014's Avatar
I would like to use something in the front fairing to keep my wire run short. Anyone with diagram?
2014 Victory CC, Two-Tone, VM1-HPT-DR, PC5, ATS+4, Llyodz HI-FLOW A/F, 1/4 Turn Throttle Ring, Tuned by Kyle Crandall of KMC PowerSports, Flashed ECM, 121hp 113tq
Suede Supersteel & Black, Madison, AL
MrXC2014 is offline
post #5 of 14 (permalink) Old 05-14-2015, 05:16 PM Thread Starter
SilvrT's Avatar
What about the aux power outlet hot wire?
2013 RED XCT
Live to Love - Love to Ride
Life's a Venture on my Victory
Lloydz Air Filter
Lloydz Timing Wheel
Power Commander V
Autotune
CATs removed
Stage 1 flash
HD Trunk Rack
FIAAM Air Horn
PIAA 1100x Lamps
D&D Slip-on Mufflers
HID High & Low
KuryAkyn Sabertooth saddlebag tail lights
Victory Apes
Michelin Primacy Alpin PA3 ZP 195/55-16
SilvrT is offline
post #6 of 14 (permalink) Old 05-14-2015, 05:44 PM
here you go
https://www.youtube.com/watch?v=kPmDkg6rc6w
post #7 of 14 (permalink) Old 05-15-2015, 10:38 AM
MrXC2014's Avatar
Yeah, I watched the video but he is not using another pwr source, he tapped straight to the batt. I was looking for a constant pwr source in the front fairing to pwr my relay in the Denali pwr distr block.
MrXC2014 is offline
post #8 of 14 (permalink) Old 05-15-2015, 10:46 AM Thread Starter
SilvrT's Avatar
For what he was doing, that's correct. Any relays would be on the other side of the junction block he was using. Different in your case tho. His junction block would provide power all the time. Relays between it and connected peripherals such as running lights would then be tapped into an ignition-on power source. (at least that's how I see it)
My setup is similar to your's except my relay and junction block are 2 separate items.
2013 RED XCT
Lloydz Air Filter
Lloydz Timing Wheel
Power Commander V
Autotune
CATs removed
Stage 1 flash
HD Trunk Rack
FIAAM Air Horn
PIAA 1100x Lamps
HID High & Low
Victory Apes
SilvrT is offline
post #9 of 14 (permalink) Old 05-15-2015, 10:51 AM
You could tap off the hid plug
vcc14 is offline
post #10 of 14 (permalink) Old 05-15-2015, 10:53 AM
Travis P's Avatar
Power outlet is on all the time... That will kill your battery.
Travis P is offline
