Overheated Transmission - Victory Forums - Victory Motorcycle Forum
post #1 of 29 (permalink) Old 06-09-2013, 08:20 AM Thread Starter
Vortex1x's Avatar
Send a message via AIM to Vortex1x
Default Overheated Transmission
I have a 2012 XC. Yesterday I went for a short (60 miles each way) ride. About 30 miles into the first leg of the ride I hit bumper to bumper, slow stop & go traffic. This lasted about 45 to 60 minutes. The temp on the display went to 97°. I could feel the heat off of the engine. I had no place to go, there was no shoulder or much shade. After I was able to get passed the traffic I was unable to keep the XC in gear, with the bike automatically downshifting. I tried to let the bike cool down but it was still hot over an hour later. I had a friend drive me back home and took my truck to pick up the bike.
Is this an issue?
Should I get the bike looked at?
Sean
2012 Victory Cross Country Black
7Jurock 14" flip windshield w/ light gray tint
Victory Stage 1 mufflers
saddlebag liners
2006 Suzuki Boulevard C50T (traded)
Vortex1x is offline
post #2 of 29 (permalink) Old 06-09-2013, 08:42 AM
ndabunka's Avatar
Is this an issue?
These are manual transmissions. What do you mean by "AUTOMATICALLY" downshifting? From which gear(s)?
It's not just any victory.... It's MY Victory!
2011 Victory Ness Cross Country #120
Ness Thunderheaders
Ness Knurled Highway Pegs/KwelMetal Brackets
Ness Radius laydown license
Chrome CAM Tension Covers
Red Engine Bolts
Madstad System
DIY Garage Door Opener
Victory Chrome Saddle Bag Lid Rails
Küryakyn Upper Fork Shrouds
Küryakyn Lower Fork Covers
Power Commander V Tuner
Power Commander AT-300
Hertz HCX 165s Speakers
JL Audio HX280/4 Bridged 140w
ndabunka is offline
post #3 of 29 (permalink) Old 06-09-2013, 08:54 AM
Something ain't right, I can sit in stop and go traffic all day in the heat of summer and not have issues like that.
2012 Vegas
N8rfastback is offline
post #4 of 29 (permalink) Old 06-09-2013, 08:55 AM Thread Starter
Vortex1x's Avatar
I mean, I had shifted up to 4th & 5th gear and the indicator on the display went down to 3rd then 2nd up to 3rd and finally down to 1st and the bike slowed down, engine revving each time.
All without me engaging the clutch or shifter.
Sean
saddlebag liners
Vortex1x is offline
post #5 of 29 (permalink) Old 06-09-2013, 09:24 AM
sounds like a clutch slipping problem, but it shouldn't be happening. I would look at the clutch if it were mine. how many miles are on the bike?
now , 2011 crossroads and 05 sportster bobber in the making
in order of ownership, sears compact scooter, honda 305 scrambler, honda 160 dream , triumph 500 trophy trail, honda cb450, sportster, honda f750, 2nd sportster, harley flh, harley super glide, 3rd sportster, bmw k1000, harley low rider, 2nd harley super glide, harley heratage, harley road king, bmw r1150rt,
thats just the street bikes!
ridealittle is offline
post #6 of 29 (permalink) Old 06-09-2013, 10:43 AM
Yup, clutch slipping. The gear indicator is electronic and calculates a guess at what gear your in based on your speed and rpm. It was getting confused even though you weren't changing gears.
2012 Vegas
post #7 of 29 (permalink) Old 06-09-2013, 11:27 AM
when you get stuck in stop and go traffic and its not moving always try to keep bike in neutral as much as possible
That means hand off clutch lever.
If you just hold clutch in your creating heat in the plates and it will start to slip and sooner or later you'll burn up the plates.
Hydraulic clutch is no different
Your clutch might be good to day. You can only adjust your clutch when the bike has sat over night. Adjusting when warm or hot will do you no good
post #8 of 29 (permalink) Old 06-09-2013, 12:50 PM Thread Starter
Vortex1x's Avatar
First off, thank you everyone for your responses.
I off loaded my XC this morning and test rode her, she is still not Engaging.
How do I adjust the clutch if that is what is needed?
Sean
saddlebag liners
Vortex1x is offline
post #9 of 29 (permalink) Old 06-09-2013, 01:00 PM
The only adjustment you have is at the far end of the clutch cable near where it connects to the cam rod behind the rear cylinder. I generally set it for 1/8" of play in the clutch lever. Do it when the bike is cold. Of course if the plates are shot it won't do a lot of good unless your cable is adjusted too tight and is disengaging the clutch a bit. Then you might get lucky and adjust it to working again. Not riding it home may have saved the clutch plates.
BBob is online now
post #10 of 29 (permalink) Old 06-09-2013, 01:49 PM
you might luck up with a cable adjustment, but, I would bet the plates are fried or warped.
