What to do with Antenna when covering? - Victory Forums - Victory Motorcycle Forum
post #1 of 18 (permalink) Old 06-09-2013, 09:14 AM Thread Starter
joelis's Avatar
Default What to do with Antenna when covering?
Ok, this is the first bike I have owned with a radio antenna.
I have tried searching the forum here, but could not find anything on my question. When covering the bike with a standard storage cover, what do you do with the antenna? Is there a special storage mount position so it will sit without bending under the cover, or do I have to cut a hole in the cover for it to stick out?
2013 AG XC
- Chrome Tri Ovals Stage 1
- Madstad Shield
- VictoryHID beams
- Kuryakyn Dually Hwy Pegs
- MCC Custom Fork Mount Deflectors
- Chrome Locking Laydown Plate Cover
- Lock & Ride Chrome Passenger Backrest
- Grasshopper Driver Backrest
- Vic Tracker Grips
- more to come...
joelis is offline
post #2 of 18 (permalink) Old 06-09-2013, 10:45 AM
RonBou's Avatar
FRIG! That's a good question. On my last trip I had a shorty antennae so I didn't have to think about it. This next trip I will be using the stock antennae. Today or tomorrow I will cover the bike in the garage and check it out.
Ron
2012 Victory Cross Country Tour (Stage 1)
2011 Victory Cross Country (traded in on XCT)
2009 Triumph Rocket III Touring (traded in on XC)
1998 Valkyrie Tourer (Hydralocked - sold as is)
1966 Honda 305 Dream (for sale)
1967 Honda 305 Scrambler (project)
1982 Honda CB900 Custom (need to put back together)
RonBou is offline
post #3 of 18 (permalink) Old 06-09-2013, 11:14 AM
you could un screw it cover the bike. If you do make sure you screw it back on tight a lot of guys have lost theres.
Bike covers are universal so they don't usually have anything in mind for antenna
post #4 of 18 (permalink) Old 06-09-2013, 12:52 PM Thread Starter
joelis's Avatar
I live in a shared condo complex with underground parking so I would be covering it regularly. Continuously removing it would probably wear it out and strip it at some point.
I guess I could make a small hole in the cover and grommet it in the right location.
2013 AG XC
- Madstad Shield
- VictoryHID beams
- Vic Tracker Grips
- more to come...
joelis is offline
post #5 of 18 (permalink) Old 06-09-2013, 01:06 PM
For everyday use I would simply replace the antenna with a shorty and save the stock long one for extended trips. Problem solved. You can find the shorty's at any auto parts store. There are lots of threads about it on this forum you can bring up with a search.
If you absolutely must keep the long antenna on; a very small pencil sized hole should do it. You can change the angle of the antenna as needed.
post #6 of 18 (permalink) Old 06-09-2013, 01:28 PM
What BBob said.. I paid around $10 for my shortie at advanced auto..
Victorypotamus
Milesx is offline
post #7 of 18 (permalink) Old 06-09-2013, 02:01 PM Thread Starter
joelis's Avatar
Thanks guys. I will pick up a shorty for it.
If I am out on the open road, I will be using MP3 anyway.
2013 AG XC
- Madstad Shield
- VictoryHID beams
- Vic Tracker Grips
- more to come...
joelis is offline
post #8 of 18 (permalink) Old 06-09-2013, 11:04 PM
OhioBoy's Avatar
I just put a shorty on mine the other day, got it from Wal-Mart for about $9. I like the fit more than the finish but it doesn't look too bad. The reception wasn't as good as the factory one but not terrible. Biggest diff. was in AM mode. but I mostly use my Iphone so I'm mostly happy with it.
2011 Cross Country
2002 HD Deuce
OhioBoy is offline
post #9 of 18 (permalink) Old 06-10-2013, 08:32 AM Thread Starter
joelis's Avatar
So this Walmart model that I have seen referenced, is it the Scosche brand? I see them online for $4.99 ?
2013 AG XC
- Madstad Shield
- VictoryHID beams
- Vic Tracker Grips
- more to come...
joelis is offline
post #10 of 18 (permalink) Old 06-10-2013, 10:57 AM
I use the cover from Beverly Bay and just bend the antenna over as I'm pulling down the cover. Have had no issues doing this, and the antenna stays straight after. It was bent over the whole winter (Nov-Mar).
Carmal is offline
