Wiring for Trailer problems - Victory Forums - Victory Motorcycle Forum
post #1 of 4 (permalink) Old 06-10-2013, 11:19 AM Thread Starter
Default Wiring for Trailer problems
I am wiring my 2011 XC for a trailer and cannot get the signal lights to work, they keep cutting out on the bike, then I have to shut off the bike and restart it to but they keep cutting out. Near as I can tell, I need to change the lights from monofilament bulb to LED. Anyone have this problem also?
Carmal is offline
post #2 of 4 (permalink) Old 06-10-2013, 11:26 AM
Squatch's Avatar
Go to electrical connection or Bushtech and get the Isolator harness. this seporates the bike from the trailer and you should have no more issues.
Squatch
USN/USCG Vet
2013 Cross Country Tour
Zumo 665 w/weather
Power Commander V
Lloydz Air filter
PTS set to +6*
Hydraulic Clutch
D&D wrapped/RPW baffles
Touring Cams
124 hp/119#ft
A country that forgets it's defenders, will itself soon be forgotten
Squatch is offline
post #3 of 4 (permalink) Old 06-10-2013, 11:28 AM Thread Starter
I was using an isolator, although not from Bushtec. Was able to get brake and taillights, just no turns.
Carmal is offline
post #4 of 4 (permalink) Old 06-10-2013, 12:24 PM
Squatch's Avatar
Sounds like you have an impeedance or resistance problem... The Isolator usually solves that issue and takes the load off the bike circuts.
Might be the isolator or the connections on the Turn signials
Squatch
USN/USCG Vet
Zumo 665 w/weather
Power Commander V
Lloydz Air filter
PTS set to +6*
Hydraulic Clutch
Touring Cams
124 hp/119#ft
Squatch is offline
