horn problems continue to baffle me......help! - Victory Forums - Victory Motorcycle Forum
post #1 of 15 (permalink) Old 06-11-2013, 06:21 PM Thread Starter
Default horn problems continue to baffle me......help!
As some of you might recall: when I hit my horn button to honk my Stebel, my bike would abruptly slow down. It felt almost like I was stabbing the brakes, but it's engine-related, not brake-related. My horn has been rewired as per KevinX's suggestion. i.e. just using the 2 OEM wires and no relay. Now I have also replaced the horn with another Stebel just to see if the horn was to blame. That made no difference and now I have a Stebel for my wife's bike.
A discovery I made today just baffles me more......if I stay on the horn button, the bike will continue to decelerate until I stop pressing the button! I brought the bike from 65 mph down to 30 mph using only the horn (same throttle and no brakes) This is getting weirder and weirder.
Any new ideas??
2011 CrossRoads (D&D, PCV w/AT, Lloydz filter/cams)
2012 Can-Am Spyder
Twin Turbo Porsche 911
FFR 1965 Cobra 427
2011 BMW 135i convertible
1941 Chevy hotrod truck
petegtsv10 is offline
post #2 of 15 (permalink) Old 06-11-2013, 06:47 PM
atomicdog's Avatar
It kind of sounds like the horn is drawing enough power to starve the ignition system, keeping it from being able to generate a big enough spark. Maybe you have bad/loose spark plug wires which would then need to draw excess current to supply the same amount of spark. Or something else in the ignition system is requiring excess current (that it shouldn't need) combine that with the current draw of the horn it may bog down the charging system.
2012 Vegas 8-ball
atomicdog is offline
post #3 of 15 (permalink) Old 06-11-2013, 06:54 PM
look at your voltage gauge when you push the horn button. If it drops below 14 volts then I'm thinking the stator and regulator are your problem. The stator puts out the amperage and the regulator brings it down to the 14 volts. Sitting still might be fine but going down the road could be a different story. If you could hook up your meter and take a ride might be a good idea.
post #4 of 15 (permalink) Old 06-11-2013, 07:43 PM
NJ8BALL's Avatar
You need a relay. That way when you Honk, it will draw power directly from the battery and not the harness. Just try it, it's easy
'09 Kingpin 8-Ball...Sanded chrome exhaust, Stage 1 slipons, VFCIII, Lloyds IAV, Stonny's 27" sissybar, Edge bags with ghost brackets,Kuryakyn black ISO grips,
http://www.bluebeardimagery.com/
http://blue-beard-imagery.artistwebsites.com/
Photo equip: Canon 60D, Canon 55-250is, Canon 18-55, Canon 70-200f4,Tamron SP10-24
NJ8BALL is offline
post #5 of 15 (permalink) Old 06-11-2013, 07:44 PM
NJ8BALL's Avatar
I tested my horn circuit when installed my horn. All you get at the wires is 12 volts, go for regular horn but for air, stebel or anything big you need the relay.
NJ8BALL is offline
post #6 of 15 (permalink) Old 06-11-2013, 09:53 PM Thread Starter
I was getting all sorts of odd engine surging issues when I had the relay hooked up. KevinX suggested eliminating the relay (it was "backfeeding). All of the surging issues disappeared w/o the relay.
2012 Can-Am Spyder
FFR 1965 Cobra 427
post #7 of 15 (permalink) Old 06-11-2013, 11:29 PM
SilvrT's Avatar
You need a relay... period. Maybe it wasn't wired properly.
Run a 12 gauge wire direct from battery positive to #30 on the relay. Have a 20 or 25 amp in-line fuse in that wire.
Run a wire (gauge isn't critical but I generally use 14 or 16 gauge from here on) from post #85 on the relay to a good ground, preferably the negative post on the battery.
Run (or extend) your positive stock horn wire to post #86 on the relay.
Run a wire from post #87 on the relay to the positive post on the Stebel horn.
Run a wire from the negative post on the Stebel horn to ground. You can tie this into the same ground wire coming off post #85 on the relay.
This works on mine... should also work on yours.
Did I say you NEED the RELAY?
Here's a pic of my wiring setup...
SilvrT is offline
post #8 of 15 (permalink) Old 06-12-2013, 01:46 AM
Bob C350's Avatar
Relay or no relay....pull the negative wire, hell pull both wires off the horn and tape them up (not shorted together of course).
Go for a ride and see if it still slows down when you press the horn button. If it does the your problem is not the horn because it's not drawing any juice.
2010 Cross Country Midnight Cherry
Touring trunk, Heated seat and grips, Vic closeouts for cold weather, Ebay fork lowers, All the low cost mods
Bob C350 is offline
post #9 of 15 (permalink) Old 06-12-2013, 04:53 AM
BeoBob's Avatar
Strange indeed.
I agree that a relay is needed to drive an air horn. It will work without it, but your stressing the contacts on the horn button. They are not designed to carry that much current and will burn out prematurely.
In any event there is definitely something wrong with your electrical system. Checked your battery terminals yet?
2013 Cross Country Tour: Custom paint, stage 1 exhaust, Lloydz Hi-Flow air filter, cams (HOH-VM1-DR), timing gear (HOH-PTS), Power Commander V, Auto Tune module, Gustafson flip shield, OEM passenger backrest with Cycle Ops luggage rack, Vic HID, heel shifter, Rockford amp, Infinity speakers all around.
2011 Cross Country: Burnt and Traded
BeoBob is offline
post #10 of 15 (permalink) Old 06-12-2013, 05:47 AM
arkiebiker's Avatar
Why not get the screaming banshee... And be DONE with it!
Searcy, AR
Blytheville, AR (Hometown and the BEST BBQ Sandwiches in the world)
Arkansas Bikers Website
http://www.arkansasbiker.net
Garmin Zumo GPS Forums
http://www.zumoforums.com
arkiebiker is offline
