AN Auto Tune AFR Question - Victory Forums - Victory Motorcycle Forum
post #1 of 50 (permalink) Old 06-12-2013, 01:59 PM Thread Starter
Default AN Auto Tune AFR Question
I recently changed my Afr from 13.9 to 13.3
And didn't like the resukts very much. Is 13.9 too lean?
What do most of you use for a target?
ch55 is offline
post #2 of 50 (permalink) Old 06-12-2013, 04:19 PM
Are all cells at 13.3?
2011 CrossRoads (D&D, PCV w/AT, Lloydz filter/cams)
2012 Can-Am Spyder
Twin Turbo Porsche 911
FFR 1965 Cobra 427
2011 BMW 135i convertible
1941 Chevy hotrod truck
petegtsv10 is offline
post #3 of 50 (permalink) Old 06-12-2013, 05:52 PM Thread Starter
yes except for the last 3 that are 13.6 @5% up to 5500rpm
BTW Im running Bassani 2into 1, wit LLoyds air filter, iac and cams
with the elevated rev limit.
ch55 is offline
post #4 of 50 (permalink) Old 06-12-2013, 07:04 PM
lunaticrider's Avatar
Did you not get it tuned after the cam install? Having an autotune is sorta a work in progress, as you can always tweak your tune. What base map are you using? There are some variables in setting up your AFR, ie. Elevation, mods etc... I've had my autotune for a couple of months and i'm constantly making adjustments to see if I can get more. I find my bike runs best in the 13.7 range up to 20% and slowly adding fuel up from there... I could probably post a pic of my afr table in a little later, my bike hauls since I've started tuning it...
2012 Hammer 8 Ball - All upgrades are listed in my Garage
If racing was outlawed ... Then only outlaws would race ...
lunaticrider is offline
post #5 of 50 (permalink) Old 06-12-2013, 07:40 PM Thread Starter
I've had 2 tunes that wernt very good. I went to people with good reps, but know HD .
I feel good with 13.9 . But was afraid it might be lean.
I would love to see your table.
I was also thinking of adding like 3 degrees ?
ch55 is offline
post #6 of 50 (permalink) Old 06-12-2013, 08:39 PM
I've added 6 degrees everywhere from idle on up to redline. My bike ran like shit at 13.9,what are you tuning for? Power? Mileage? Depending where the 13.9 is on your map, yes that can be fairly lean. I'll post up a pic as soon as I can get these crazy kids into bed...
post #7 of 50 (permalink) Old 06-12-2013, 08:41 PM
The gain from the advance is huge, also setting up your accel pump is a big difference...
post #8 of 50 (permalink) Old 06-12-2013, 08:43 PM
+6? I have mine at +4 as per Lloydz recommendations BUT I also run 87 octane. I'm interested in seeing your map also. Mine is set to 13.7 up to 13.4 at 6500 rpm. I attempted to mirror A/F of posted good dyno runs.
Ride safe.
2011 CrossRoads
D&D pipes, PCV, Llyodz performance filter w/strip in place, Llyod's timing wheel (set +4) and various other visual do dads. :cool:
vagabondjpm is offline
post #9 of 50 (permalink) Old 06-12-2013, 08:53 PM
Ride safe.
Is lloydz recommendation with his timing wheel installed as well? I know everyone says the pcV only adjusts over 2500 rpm but I've never seen any data to back this up, the pcV software shows it is advancing at idle and if you take the advance away at idle up to 2500 in the software you can feel it so until I see data that proves otherwise that the pcv doesn't do anything under 2500 rpm i'll go with what my butt dyno is telling me...
post #10 of 50 (permalink) Old 06-12-2013, 08:58 PM
My +4 is from the wheel only. In the PCV, it is set to 0. I have heard the same also but never messed with the PCV setting as I installed the wheel before the PCV.
2011 CrossRoads
