Installing Brake Light Modulator - Victory Forums - Victory Motorcycle Forum
post #1 of 5 (permalink) Old 06-16-2013, 10:01 PM Thread Starter
VMChief's Avatar
Default Installing Brake Light Modulator
Hello all,
Could use some help installing a brake light modulator. I understand the concept of tapping into the brake light feed, but where is that wire?
Crawled underneath today and saw wiring harnesses leading to the ABS module. The module seems to block access to the wires leading directly to the brake light that I need to tap into. How do you remove the brake light assembly to gain access to the wires leading to it? Or is there a better way?
Thanks in advance
2012 Cross Country
2008 Vegas Low (for the wife)
2006 Yamaha V-Star 650 (parked for now, but will train the 19 yr-old boy on fixing and riding before long)
Crestview, Florida/Eglin AFB (USAF)
VMChief is offline
post #2 of 5 (permalink) Old 06-17-2013, 06:30 AM
bnhender's Avatar
Originally Posted by VMChief View Post
Hello all,
Thanks in advance
I tapped into mine under the seat. There is a harness leading back that encloses all the wires. Your instructions should tell you the wire colors of the yous you need.
There is another string on this forum that explains this pretty well.
___________________________________
Bill
2012 Cross Roads (Sunset Red)
Stage 1 flash
Lloydz Air Filter
Lloydz Idle Control Valve
Lloydz Adjustable Timing Wheel
Freedom Performance True-Dual Exhaust
VM1-DR cams
O2 Sensors disconnected
21" Adrenaline Front Wheel
Cee Bailey 24" windscreen w/ lowers
Tachometer
Small Bullet Light Bar
LED Headlight
Grasshopper driver backrest
Victory passenger backrest
Chrome saddlebag rails
2017 Octane
Shorty pipes
Navasota, TX
bnhender is offline
post #3 of 5 (permalink) Old 06-17-2013, 07:50 AM
I also tapped under the seat. Don't forget the resistor. If you need one, PM me.
Ride safe.
2011 CrossRoads
D&D pipes, PCV, Llyodz performance filter w/strip in place, Llyod's timing wheel (set +4) and various other visual do dads. :cool:
vagabondjpm is offline
post #4 of 5 (permalink) Old 06-18-2013, 08:04 PM Thread Starter
VMChief's Avatar
Thanks guys. Can you post a link to the thread? I did a search but can't find it. What resistor is needed?
2012 Cross Country
VMChief is offline
post #5 of 5 (permalink) Old 06-18-2013, 08:40 PM
I installed a set of Hyper lites and tapped into the brake lines connected to the tour box... Nothing else / no resistor needed.
https://www.victoryforums.com/showthr...ght=hyperlites
2012 Cross Country Tour - VroomHilda
Dobeck EJK Gen3 Fuel Tuner
Tri Flo Ovals
Vic K&N knock off Air filter
Lloyds Timing Wheel +2
Relocated Air Shock fill hose
WD SkidPlate reinforced
Hyper running/brake lights
Garmin GPS
Existential Secular Humorist with warrior Buddhist leanings
*Rider/Owner continuous since 1973 - 877,000+ miles USMC R
SemperVee is offline
