Right Saddlebag depatrted bike on freeway - Victory Forums - Victory Motorcycle Forum
post #1 of 19 (permalink) Old 06-17-2013, 12:05 PM Thread Starter
pogie's Avatar
Default Right Saddlebag depatrted bike on freeway
I was traveling home on the freeway when a truck pulled along side me and pointed at my bike like somthing was wrong, so i pulled over to take a look . Immediately seen the right saddlebag missing. I had to back track 4 mi to locate the saddlebag. of course it was afu, but i was able to retrieve all the contents. Im not sure why the fasteners come out. Ive never had a problem with them disconnecting before and im positive they were securly installed the last time I reinstalled the bag. Anyone have this problem?
Frank J Pogline Jr
USN Chief Petty Officer RET.
AMEC(AW)
2011 Sunset Red Crossroads
Atom bomb pipes
pogie is offline
post #2 of 19 (permalink) Old 06-17-2013, 12:33 PM
your not the first. Victory's use the worst locking pins ever.
Go to hardware store and buy two J nuts 5/16 size and get two bolts.
Pull off the stock pin clips and replace with the J clips.
Sorry now you will need a wrench to un bolt the two bolts but they will not come off and you don't need to do all four
post #3 of 19 (permalink) Old 06-17-2013, 12:55 PM
Send a message via AIM to JackPt
Well this is good to know as I was looking to purchase a slightly used cross country next year to sit next to the Jackpot.
2014 Cross Country (Two-Tone Suede Supersteel & Black) Chrome D&D exhaust, Power Commander V, Lloydz air intake, Klockwerks tinted flare windshield.
*sold*2008 Jackpot (color midnight cherry with a ton of mods)
JackPt is offline
post #4 of 19 (permalink) Old 06-17-2013, 06:47 PM
ammo_umb's Avatar
Sucks but it happens. Always check to make sure the pins (dzus fasteners) are engaged because the d-ring tend to get snagged and rotate when you put things in / take things out of your bags.
BTW they've used pins just like these on HD bags for years and used the same type fasteners on aicraft panels for a lot longer. They are far from being "the worst locking pins ever" but they do have to be watched.
Replace at least one pin on each bag with a nut plate (J-nut) and a bolt and you'll never have to check them again.
Retired USAF, IYAAYAS!
ammo_umb is offline
post #5 of 19 (permalink) Old 06-17-2013, 07:07 PM
I'm going to go out on a limb and say that our cross bikes don't vibrate near as much as a UH-60A/L does. The reason they don't come open on our aircraft very often is we check them before each flight.
I did however buy 2 nut plates and bolts at Lowes today. It's just too cheap of an Insurance policy if I do get careless and miss them on pre-flight.
To the OP, I'm sorry this happened to you, but the fasteners aren't junk. You very well may have had a couple bad ones, it happens. Just sucks for the person that gets the bad one.
Riding a 2012 Imperial Blue Cross Country
Creek_IP is offline
post #6 of 19 (permalink) Old 06-17-2013, 09:07 PM
XKnight's Avatar
Seems like a fairly well documented problem. That's why one of my first mods was installing the Brukus SaddleBagSecure bolts.
http://brukus.com/cgi-bin/p/awtp-pro...parts&pc=12995
XKnight is offline
post #7 of 19 (permalink) Old 06-17-2013, 09:36 PM
The man has a good thing going and people are buying it. For @ $8.50, I bought the hardware and will secure the bags just as good as his kit.
Creek_IP is offline
post #8 of 19 (permalink) Old 06-18-2013, 05:38 AM
TNXR's Avatar
I did the same, went to lowes and got the hardware to replace one pin on each saddlebag. Burkus may be nice but not $35 nice!
2011 Cross Roads Sunset Red
TNXR is offline
post #9 of 19 (permalink) Old 06-18-2013, 06:29 AM
irv
irv's Avatar
havent had this problem yet, but will admit to 3 times of
going down the hiway with a winged bike[1 bag cover open].
you have to make sure they are fully latched. at least the
hinges are strong. so far it has been witnessed by my wife
and 2 harley riding friends. didnt hurt anything but my pride.
mph faster].
irv is offline
post #10 of 19 (permalink) Old 06-18-2013, 08:33 AM
Squeak's Avatar
Try these.
http://buywitchdoctors.com/p/1429/vi...lebags-sc-481/
Greg (Squeak)
Air Force 1968-1972
Vietnam Veteran - Danang AB
Security police
2013 Victory Cross Country Tour (Crimson Red)
Lloydz Cams
Tri-oval exhausts
Power Commander 5
Power Commander Auto Tune
Squeak is offline
