Rear Axle Nut Torque method - Victory Forums - Victory Motorcycle Forum
post #1 of 15 (permalink) Old 06-23-2013, 07:38 PM Thread Starter
TechnoGeek's Avatar
Default Rear Axle Nut Torque method
I am trying to align my belt, but wondered how to torque it to 65Ft lbs?
My torque wrench and socket will not fit unless I take the Left exhaust off. Is that the procedure?
Another question....
When adjusting the rear axle adjustment nut, I get a lot of movement of the wheel, so I assume i should just keep pressure pushing the wheel toward the front at all times.
thanks.
I reject your reality, and submit my own!
2012 Cross Roads, Utopia Drivers Backrest, Victory Passenger Backrest, Tall Windshield, Lowers, Mirror Extenders, 3m Clear Paint Protective film.
TechnoGeek is offline
post #2 of 15 (permalink) Old 06-23-2013, 08:05 PM
TNXR's Avatar
You need to invest in a 27mm crows foot to attach to your torque wrench. If you leave the crows foot at a 90 degree angle you can leave the torque at 65 foot pounds. If you have it straight out you will have to alter you torque value. I can't remember off the top of my head but there are several websites that can describe it and let you plug in you numbers and give you the torque pounds. And yes, keep pressure on the tire in a forward direction.
2011 Cross Roads Sunset Red
TNXR is offline
post #3 of 15 (permalink) Old 06-23-2013, 08:08 PM
right axle adjuster is for belt tightness left adjuster is for left and right. You want the belt in the middle so get it on the laft side and roll wheel till it just comes off the left hand lip.
To bad Vic doesn't use a 1/8" narrower belt life would be easer.
You want whats called a crows foot that way you don't have to pull every thing off. Sears might have one.
here is what they look like and there is no need for a hole set
post #4 of 15 (permalink) Old 06-23-2013, 08:57 PM
Luciferiad's Avatar
...I loosen the exhaust clamp for the left pipe at the crossover (15mm) and take out the two bracket bolts under at the end of the pipe (13mm). Not really a lot of extra work, and I didn't have to go buy another tool I'd use for only one thing once every couple years.
Mine:
2011 Cross Roads, crimson red
Hers
2015 Vegas 8-Ball
Luciferiad is offline
post #5 of 15 (permalink) Old 06-23-2013, 09:29 PM
ByteN2it's Avatar
You can also use an spanner torque wrench rather than a ratchet style. Less than $100 at Amazon- It's good to have tools, Brian
ByteN2it is offline
post #6 of 15 (permalink) Old 06-24-2013, 05:23 AM
TNXR's Avatar
You can get the tools you need from amazon for pretty cheap, think I paid $3 or so for the crows foot. I also picked up the correct hex socket for the front tire in case I need to take it off while I was at it.
TNXR is offline
post #7 of 15 (permalink) Old 06-24-2013, 07:37 AM
gamewarden's Avatar
TNXR
What was the metric size for the allen wrench to remove front axle??
Thanks
2011 custom Tequila Gold with Candy Orange accents, hard lowers and trunk, Ipod in lowers, HID and saddle bag bars, stage 1, heel shifter, front and back chrome fender guards,Garmin GPS, fairing wind deflectors, heated Gerbing hook up, Dain skull brake pedal, rear brake master and reservoir cover, custom cheese wedge cover, clutch cover, Witchdoctor cam covers, Wolo Bad Boy horn, heated grips and seat, Gorilla alarm, Vision rear engine brackett covers, Kruzer Caddy, WD exhaust tips.
gamewarden is offline
post #8 of 15 (permalink) Old 06-24-2013, 11:23 AM
Originally Posted by gamewarden View Post
TNXR
Thanks
5/8" allen
post #9 of 15 (permalink) Old 06-24-2013, 12:13 PM
TNXR's Avatar
Don't know the metric size for the front axle off the top of my head but if no one responds I'll get the size this evening.
TNXR is offline
post #10 of 15 (permalink) Old 06-24-2013, 02:48 PM
TNXR
Thanks
5/8" = 0.625"
0.625" * 25.4 (mm per inch) = 15.875mm
16mm.
