Cams, VFC3 & Timing Wheel - Victory Forums - Victory Motorcycle Forum
post #1 of 7 (permalink) Old 06-30-2013, 03:11 PM Thread Starter
toejam's Avatar
Default Cams, VFC3 & Timing Wheel
Just got back from visiting Rylan Voss in Iowa this past thursday to get cams, vfc3 & timing wheel. Great service and friendly to boot! Here's the results before & after:
2013 Anti-Freeze Green XC
Vance & Hines Slip On's
BadBoy Horn, PCV
Gustafsson +4 Windscreen
Picasso Nano PN2.350D Amp
HMD520 Gorilla Bagger Bars
2010 XC 116 Big Bore - Gone
2006 Hammer - Gone
toejam is offline
post #2 of 7 (permalink) Old 06-30-2013, 06:25 PM
Good for you. Enjoy the ride!!!
2010 XC Midnight Cherry
cams/D&D
2009 Ness Vision
116 Big Bore
"The Millinium Falcon"
Blueline is offline
post #3 of 7 (permalink) Old 06-30-2013, 06:40 PM
beast30's Avatar
Numbers look good. On the first run did you still have the o2 sensors plugged in? What setting did Rylan put your timing wheel at? One more quesion..what exhaust are you running? Thanks
2012 XC Imperial Blue/Blacked out, LLoyds filter, LLoyds timing wheel,
VM1 DR cams, PC5, LLoyds ECM, Big Gonzo, KM meat hook bars (internally wired), Conquest underdrive pulley, KM instrument bezels, JTD lowers with speakers, PBR300 amp with Polk 6.5, .40 cal cheese wedges, tinted turn and tail
beast30 is offline
post #4 of 7 (permalink) Old 06-30-2013, 07:23 PM Thread Starter
toejam's Avatar
No o2's at base dyno, read my sig for exhaust. I assume the timing is +4 as is most are set as I have read.
BadBoy Horn, PCV
2006 Hammer - Gone
toejam is offline
post #5 of 7 (permalink) Old 06-30-2013, 08:43 PM
beast30's Avatar
Cool, the sig line doesnt show up using the app on my pad. But looked at your profile and found what i was looking for. Cheers and enjoy
beast30 is offline
post #6 of 7 (permalink) Old 06-30-2013, 11:31 PM
BBob is online now
post #7 of 7 (permalink) Old 07-01-2013, 01:22 AM Thread Starter
toejam's Avatar
Guess I should add to my sig that I have the Lloydz rev extend flash - really helps it come alive and keep pulling!
BadBoy Horn, PCV
2006 Hammer - Gone
toejam is offline
