Steering Head Torque Spec Please - Victory Forums - Victory Motorcycle Forum
post #1 of 14 (permalink) Old 07-03-2013, 12:00 AM Thread Starter
Default Steering Head Torque Spec Please
I have my XR up on the lift and checked the steering head bearing and found them to be a tad loose. Anyone know the torque spec for them and what is the size of the socket required for the job? Looks to be 30mm.
RICZ is online now
post #2 of 14 (permalink) Old 07-03-2013, 05:35 AM
TNXR's Avatar
Looking at the service manual they call the top nut the "crown nut" and should be torqued to 72 lbs. I think you may have to have a special socket to do the job though.
2011 Cross Roads Sunset Red
TNXR is offline
post #3 of 14 (permalink) Old 07-03-2013, 09:51 AM Thread Starter
THNX TNXR! I always wanted to do that. I may need a thin wall socket as there isn't much room for a thick one it appears.
Back in '05 I attended a Motorcycle Touring Association rally in Lake Lure. What a lovely location. Close to Chimney Rock is the little town of Bat Cave. That would be neat to have as a return address. We had a group dinner at Hawg Wild BBQ in Hendersonville and they had the bestest hush puppies we ever ate. We had good times there in TN. Rode out there and back from Portland.
RICZ is online now
post #4 of 14 (permalink) Old 07-03-2013, 10:56 AM
TNXR's Avatar
Checking the torque of the steering head bearing is one of the few things I couldn't do when I did my own 500 mile service. My bike is still in the shop waiting for my rear shock to come in but when I pick it up I might see if they will let me borrow the special socket to check mine with.
TNXR is offline
post #5 of 14 (permalink) Old 07-03-2013, 04:34 PM
If the torque is 72 ft pounds you have to ask your self is that with the bike off the ground or on the ground.
How do you do any thing to your bike with out a manual
post #6 of 14 (permalink) Old 07-03-2013, 05:00 PM
Pop
I use my manual to get the front tire high enough that I can get the jack under the bike. Does that count?
Red.
2012
Cross Country Tour.
We can't help it
We just keep moving
It's been that way since long ago
Since the stone age chasing the great herds
We mostly go where we have to go
That was written by James McMurtry
Pop is offline
post #7 of 14 (permalink) Old 07-03-2013, 07:26 PM
I believe what tightens the steering bearing is the adjuster nut under the top triple clamp which is held on by the crown nut. The crown nut is 72 ft pounds. The adjuster but is 29 ft/lbs and then you loosen it
1/4 turn. You need a very specialized wrench to torque it. My old school training says raise the bike on a lift and tighten the adjuster but to the point where there is a little resistance as the steering falls side to side. If ihe steering falls and bounces against the stop I would think its too loose. It doesn't, need much torque on it to achieve this, probably in the range of 5-7 ft pounds. If you get aclunk in steering when coming to a stop or a significant wobble in your steering around corners then tightening the adjuster
Nut may help, probably no more than 1/8th of a turn at a time. Do this at your own risk but this is how I do mine
Tom
2013 Cross Country Tour Bronze Mist
TomS209 is offline
post #8 of 14 (permalink) Old 07-05-2013, 06:36 AM
wesdalton's Avatar
Tom
Way too much common sense there, don't you know you need at least three engineers and a couple of manuals to accomplish what you just did?
2010 X C
wesdalton is offline
post #9 of 14 (permalink) Old 07-05-2013, 11:25 AM Thread Starter
Well folks, I cheated those engineers and manual writers that have you tearing the front end apart to tighten the adjuster nut that requires a special wrench, so they say. How, you ask? Circle 'round kiddies and Gramps will tell you that tale.
I got me a 30mm socket and loosened the crown nut, the one at the very top, you see. Then I gets me a long straight screwdriver and a hammer. I places the tip of the screwdriver in one of the notches on the adjusting nut (which is in plain sight under the triple clamp, don't ya know) and tap, rotating it tighter. I checks the forks for slack and when there's none, I stop the tapping and tighten the crown nut to 72 ft. lbs. with my handy dandy torque wrench. Then I goes for a ride. No more clunking when I hits a bump. 'Course I don't know if'n I have the adjusting nut set at the correct torque, but everything seems to be in good working order.
Thanks for all yer suggestions and referrals. Once I peered under the top triple clamp and saw that the adjusting nut is exposed, it was an easy fix from there.
RICZ is online now
post #10 of 14 (permalink) Old 07-05-2013, 12:49 PM
BeoBob's Avatar
Is there a mechanism that locks the adjuster nut in place, or is it held tight by the 72ft/lbs on the crown nut???
2013 Cross Country Tour: Custom paint, stage 1 exhaust, Lloydz Hi-Flow air filter, cams (HOH-VM1-DR), timing gear (HOH-PTS), Power Commander V, Auto Tune module, Gustafson flip shield, OEM passenger backrest with Cycle Ops luggage rack, Vic HID, heel shifter, Rockford amp, Infinity speakers all around.
2011 Cross Country: Burnt and Traded
BeoBob is offline
