Does your BAG fit right? - Victory Forums - Victory Motorcycle Forum
post #1 of 10 (permalink) Old 07-03-2013, 10:09 AM Thread Starter
SilvrT's Avatar
Default Does your BAG fit right?
Noooooooo.... not THAT bag!!!
My right saddlebag lid does not completely seal against the rubber at the front. I can see the edge of the rubber seal and I can stick my finger between it and the lip of the bag, all the way in.
This can't be right ... are the hinges/latches adjustable?
SilvrT is offline
post #2 of 10 (permalink) Old 07-03-2013, 10:30 AM
Squatch's Avatar
I have a simular problem on the rear side of the bags, allow a lot of dirt and some rain water to get pulled in.
Thinking of changing or adding more gasket to the rear. and front.
Squatch
USN/USCG Vet
2013 Cross Country Tour
Zumo 665 w/weather
Power Commander V
Lloydz Air filter
PTS set to +6*
Hydraulic Clutch
D&D wrapped/RPW baffles
Touring Cams
124 hp/119#ft
A country that forgets it's defenders, will itself soon be forgotten
Squatch is offline
post #3 of 10 (permalink) Old 07-03-2013, 10:52 AM
TNXR's Avatar
This topic has been brought up before and I started a thread with pics a few months back. Neither one of my lids close the same and the right bag has a large gap on top. I brought it up to the dealer and compared to the other XC's on the floor and they all were about the same so I quit fighting it. I then put on some door seal tap on the front and rear of each bag lid and that has helped alot with keeping dust out. I have been through several heavy rains and have yet have water get in the bags. I was worried that the overspray from the front driving through rain would get in the bags but it has not. The bags are a crappy design in that you can not adjust them very well.
Something else you may want to check is the hinge mechanism on the underside of the lid. Mine has started to wear where it contacts the "U" shaped latch because of how loose the right bag is. I stuck a pencil in the rubber dampner to expand it and that has helped with the loosness as well.
2011 Cross Roads Sunset Red
TNXR is offline
post #4 of 10 (permalink) Old 07-03-2013, 11:30 AM Thread Starter
SilvrT's Avatar
Thanks for the helpful info.
So, when you were talking to the dealer about it and even though others were the same, ma Vic would not correct it ... no recalls ??
SilvrT is offline
post #5 of 10 (permalink) Old 07-03-2013, 12:23 PM
Send a message via Yahoo to cptmorgan
Had same problem on mine.
Dealer fixed mine with extra lids seals.
2012 XCT
cptmorgan is offline
post #6 of 10 (permalink) Old 07-03-2013, 02:00 PM
anrman's Avatar
Down here, we just break out the duct tape. Solves all kinds of problems.
2013 Cross Country
LLoydz's VFCIII, RPW Cross Muffler
Former Bikes
2011 Cross Roads
2009 BMW K1300S
2005 BMW K1200S
anrman is offline
post #7 of 10 (permalink) Old 07-03-2013, 02:24 PM
TNXR's Avatar
I think they would have if I pushed the issue but figured the odds were that I would just get another set of bags that had similar problems since the ones in the dealership were not much better than mine.
TNXR is offline
post #8 of 10 (permalink) Old 07-03-2013, 03:03 PM Thread Starter
SilvrT's Avatar
We Canucks are a bit more "refined" ... we use Tuck Tape now ... far better than Duct tape and it's Red so matches the scoot color.
SilvrT is offline
post #9 of 10 (permalink) Old 07-03-2013, 04:17 PM
Not knowing what year you have or what model I would say go to dealer and ask for a new bag. Other guys have had the same problem
post #10 of 10 (permalink) Old 07-03-2013, 04:22 PM Thread Starter
SilvrT's Avatar
As you can see, I've updated my sig.
2013 RED XCT
Live to Love - Love to Ride
Life's a Venture on my Victory
Lloydz Air Filter
Lloydz Timing Wheel
Power Commander V
Autotune
CATs removed
Stage 1 flash
HD Trunk Rack
FIAAM Air Horn
PIAA 1100x Lamps
D&D Slip-on Mufflers
HID High & Low
KuryAkyn Sabertooth saddlebag tail lights
Victory Apes
Michelin Primacy Alpin PA3 ZP 195/55-16
SilvrT is offline
