iPod cable issues - Victory Forums - Victory Motorcycle Forum
post #1 of 8 (permalink) Old 07-06-2013, 06:20 PM Thread Starter
joelis's Avatar
Default iPod cable issues
Was out riding today, had my iPhone 4 plugged in to the iPod cable in the saddlebag, everything was fine until I hit a big bump in the road. The stereo went fuzzy, and then the display went from showing the Song Track etc to just showing AUX. Lost all functionality except volume control. It started acting like it was connected via bluetooth. I stopped and turned everything off, including my phone and then rebooted everything. Still the same issue. iPhone no longer charges when plugged into cable, and no controls work except volume.
Any ideas? The fact that the songs still play, and the volume still works tells me that the cable didn't come unplugged somewhere, but maybe now just a bad cable that needs to be replaced?
2013 AG XC
- Chrome Tri Ovals Stage 1
- Madstad Shield
- VictoryHID beams
- Kuryakyn Dually Hwy Pegs
- MCC Custom Fork Mount Deflectors
- Chrome Locking Laydown Plate Cover
- Lock & Ride Chrome Passenger Backrest
- Grasshopper Driver Backrest
- Vic Tracker Grips
- more to come...
joelis is offline
post #2 of 8 (permalink) Old 07-06-2013, 06:42 PM
First thing I would do would be to unplug and replug the iPod. If that doesn't work, try rebooting/resetting your iPod. Not a factory reset, just a complete power down/power up...
post #3 of 8 (permalink) Old 07-06-2013, 07:19 PM Thread Starter
joelis's Avatar
Ya I did all that. I even tried plugging in my wife's iPhone. Same thing. So it is something with either the cable or the base unit.
2013 AG XC
- Madstad Shield
- VictoryHID beams
- Vic Tracker Grips
- more to come...
joelis is offline
post #4 of 8 (permalink) Old 07-06-2013, 08:29 PM
I had this happen to me once, and ended up having to unplug and reconnect the IPod cable where it connects to the saddle bag connector. After that all was fine.
2011 Cross Country
Lloydz HOH-VM1-DR Cams
Arlen Ness Big-Shot 2 P/N 18-627
Performance Air Filter
D&D exhaust
Gustafsson +4 Shield
I POD
Adjustable lowering Link
Kicker PS52504 Speakers
Titan Amp BT454
08 VTX1800F sold
06 1200R Sportster sold
1979 Yam 750 Special sold
simpletruth is offline
post #5 of 8 (permalink) Old 07-07-2013, 09:36 AM Thread Starter
joelis's Avatar
Yep, that was it. Once I removed the saddlebag, I saw that one of the two wire couples from the cable to the harness was not snapped in to the clip all the way. I snapped it back in place and all is good.
2013 AG XC
- Madstad Shield
- VictoryHID beams
- Vic Tracker Grips
- more to come...
joelis is offline
post #6 of 8 (permalink) Old 07-09-2013, 09:47 AM
steviej's Avatar
This happened to me as well. I guess there was not enough slack in the cable when installed. The little clip that holds the connector together broke so the connector is loose. Rather than shell out another c-note for a new cable, I just put one of those plastic covered wire twisties (like what come in the box of hefty lawn/trash bags) through it long wise and twisted it tight. This holds it together with no problems. And it is an easy undo when I want to take the saddlebag off.
steviej
steviej is offline
post #7 of 8 (permalink) Old 07-16-2013, 04:01 PM
BruceI's Avatar
I have a XCT that suddenly does not recognize my IPOD. Wondering if anyone else has had this issue on the XCT. There is a connector under the front of the tank that seems to lead to the left front glove box. That connector seems secure. Wondering if there is another connector for the IPOD between the front and back pieces of the lower?
2012 Cross Country Tour
2008 Royal Star Venture
BruceI is offline
post #8 of 8 (permalink) Old 07-31-2013, 01:16 PM
Metalb00's Avatar
the ipod cable connects in the lower, the outer shell of the lower comes off with 4 metric screws. there is a connector under the tank those eventually go to
2012 Cross Country Tour (sold)
2016 Magnum x1 (no more)
Metalb00 is offline
